Just bought an R34 GTT, need some help from you guys, the car has TIEN shocks and springs, the ride is bone breaking, the roads in the Philippines are bad with holes and bumps everywhere, so makes it hard to drive when the ride is so stiff, have reduced 10-20psi, but still very stiff, front end seems to bounce now, i am thinking of changing all the shocks and springs, car is not used on track, just street use, so i'm in need of your help to suggest the best shocks and springs, for a smoother ride, but still keeping all the performance, car runs great, but would enjoy it more if it were a smother ride. Thank you and regards to all. Phil
https://www.sau.com.au/forums/topic/303000-help-suspension-help/
If what you have is too hard I'd be going for a lower spring rate for the next set you buy. I had Swift springs in my WRX and they were as comfortable if not more so than stock and they were lowered, I'm not sure if they do a set for skylines but you can always do a bit of Google searching.
I bought the medium rated springs from TEIN and they are pretty good. Slightly stiffer than standard. They also make a soft version so you might want to look at that. Being in the Philippines I'm not sure what is locally available but here Bilsteins, Koni shocks are pretty good and but can be pretty pricey.
Depending on your budget you can get some new coilovers which are adjustable but get them with a low spring rate as stated. Otherwise the standard newish suspension is always another option!
    • Do you think the guys in Penrith are install the E85 Kit?
    • Thanks Pac!   I will reach out to them!
    • Yes, but 2 things of the top of my head, 1. Legalities of nitrous on a street car. 2. No chop chop. I fully understand that there's much cheaper ways to make power, and whilst a wet 50 shot is fairly cheap to install, bottle fills are expensive, and bottles always need to be refilled, and nitrous also has its own inherent issues with reliability, and tuning, from my experience of others using nitrous, it doesn't take alot to lunch a engine real quick if something goes slightly wrong when spraying, if I wanted a big chunk of additional powers, a spooly boy would make alot more sense, disregarding the additional engineering, supporting mods and other logistical issues of sticking a spooly boy on a car that came naturally aspirated from factory  In the end I'm not racing for sheep stations, and I don't really care if people make more power, or are faster than me, or spend less, or more than me, the only thing the car needs to do is drive around and make me smile, which it is doing now Really, I just want a shiny new intake to look at when I'm cleaning the engine bay, and of course, some more induction doorts, and maybe even that 5kw for that elusive 200hp cherry on top that I might get If the FAB9 intake plenum, TB and air filter box thing doesn't eventuate for whatever reason, Plasmaman do one, not as fancy looking, and a fair chunk of more cash is required when including the TB and other bits and pieces that are required to install it, but, it is another option that is available to me if FAB9 one does fall down (but I really, really.....really, want the FAB9 one though) TL;DR. You want what you want
    • Been so long since I have been here,seeing SDU is dead. I had that problem on my gtr in 2006 but luckily there was no engine damage,it was inspected by Hytech Engines,race bearings and extended crank collar put in and that was about it. Hopefully yours is sorted now.
