Me and my friend were having a argument about boost, and he told me to post on here to find out who was right so here goes.
He says - Adding an aftermarket free flowing exhaust will increase ur boost...
I say - Go f**k ur self, the boost controller controls the boost way before the exhaust flow has anything to do with it.
Thoughts... and please only people that know something about this as yeah.... Neither of us are adimiting to being wrong! THIS IS SRS BUSINESS!
So help me SAU prove me right!
https://www.sau.com.au/forums/topic/303012-boost-arguement/
theoretically speaking you are correct. theoretically you shouldn't see any boost increase from changing the exhaust as the pessure in the intercooler piping is what determines the boost level and you could remove the exhaust all together and it shouldn't alter the boost level. this doesn't always happen in the real world though. sometimes turbulence, etc from aftermarket exhausts can actually restrict the wastegate gases and cause them to have to flow throught the compressor wheel and give you an inceased boost pressure
that said, i never saw a boost increase when adding a turbo back exhaust or intercooler, but others have. i still had 7psi all the time using the wastegate and solenoid only with a 3" turbo to cat and 3.5" catback.
https://www.sau.com.au/forums/topic/303012-boost-arguement/#findComment-5023321
You're wrong. He is right.
Exhausts that "choke" turbo cars, restrict them.
Restriction causes backpressure, backpressure is the enemy of turbocharhing in many ways.
You put a free flowing exhaust (vs stock) on a R33, you'll see a psi or two increase right away.
https://www.sau.com.au/forums/topic/303012-boost-arguement/#findComment-5023324
change the cat back on just about any early mazda (familia gtr) and the boost raises to the point of boost cut, changing exhaust definatley can have an effect on boost, it all depends on how restrictive it is to begin with, subaru's are also prone to overboosting with str8 through turbo back exhausts.
https://www.sau.com.au/forums/topic/303012-boost-arguement/#findComment-5023357
Stock 2jz supra twin turbo's use a restrictor in the exhaust to reduce exhaust flow. Once thats removed boost climbs to 15-18 from memory.
I put an 80mm nismo catback on my R34 gtr and it went up to 1 bar with the stock ecu, now though with the power fc (and no boost controller kit) its back to 0.8 bar max.
https://www.sau.com.au/forums/topic/303012-boost-arguement/#findComment-5023401
how so, i had a 3inch turbo back, with high flow cat. and it didnt change at all on my boost gauge, was still running 7psi.. from stock exhaust to 3inch turbo back...???
how does the exhaust over right the boost controller i get that it might spike over 7psi because there are less restrictions in the way etc... but how will it flow over what the boost controller will let it?
***EDIT***
im not looking to argue on here, im just looking for an explanation :)
Edited by Alexxs
https://www.sau.com.au/forums/topic/303012-boost-arguement/#findComment-5023402
Pass, most people I know have had a bit of a gain when changing exhaust. From memory, stock R33s I have been in run 5psi stepping up to 7psi with stock exhaust and 7psi stepping up to 9psi with full exhaust. 7psi flat if the boost solenoid is eliminated...
https://www.sau.com.au/forums/topic/303012-boost-arguement/#findComment-5023417
when i changed the full exhaust system in my 33 the boost went up 2psi.
it ran with stock exhaust- 5psi until 4500rpm, then jumped to 7psi.
with aftermarket turbo back system- 7psi until 4500rpm, then jumps to 9psi.
so yes it does change.
https://www.sau.com.au/forums/topic/303012-boost-arguement/#findComment-5023423
Everybody is right as this is the basics of turbo understanding. If this is a standard R33 then boost will increase a little if exhaust is changed yet other cars might not gain anything. How many times have we had a problem with rich and retard due to exhaust and intercooler being changed to a far more efficient type. An EBC will control that boost but that boost will still come on earlier due to less restriction. Lets face it, most manufactures use exhausts to limit boost or to pass EPA laws.
https://www.sau.com.au/forums/topic/303012-boost-arguement/#findComment-5023483
a free flow exhaust makes boost come on sooner (ramp up faster) but as you say, EBC should set desired PSI. Once set psi is reached, it is the same between the two cars (although the one with the open exhaust is making a bit more power at that psi due to less back pressure).
However if you look at the dyno graphs which show PSI, you'll frequently see roll off at the top end. This is where a free flowing exhaust might help, after fitting, it should stay at the target psi for longer and therefore make more peak power due to the higher psi at 8000 rpm.
https://www.sau.com.au/forums/topic/303012-boost-arguement/#findComment-5023748
Without adding a boost controller, and just by adding zorst + intercooler, it's possible to get from 7psi (stock max) to around 8-9 psi.
That's what I hear from trolling these forums as if my life depended on it, however have no factual evidence to back it up! :rofl:
https://www.sau.com.au/forums/topic/303012-boost-arguement/#findComment-5024201
You're both right!
It depends if you have a proper closed loop boost controller which actually measures boost pressure, or a factory type setup which is made to give a certain pressure when the stock restrictions like exhaust and IC are in place.
So on a factory car he is right, removing restrictions makes the whole system work better and you get a boost increase.
On a car with a proper EBC you are right, the boost is being measured and digitally controlled without any regard to restrictions, so it should stay pegged at whatever its set to no matter what you change around it.
https://www.sau.com.au/forums/topic/303012-boost-arguement/#findComment-5024264
Before I did exhaust and cooler, I had previously changed my 33 to 7psi all the way through the factory boost solenoid.
This was confirmed by an A/M boost gauge. When I added the Catback exhaust and Front mount IC (front half of exhaust came later), my boost increased upto roughly 9psi. However didn't notice any change when I completed front half of the exhaust.
Luke
https://www.sau.com.au/forums/topic/303012-boost-arguement/#findComment-5024605
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
