Hey,
Ive just started doing 3d cad work and basic CFD. I have the software etc to do more complex CFD but I have just been modelling air flow through cooler piping n such. Want to eventually model plenums and exhaust manifolds. Im not interested in this as a profession or anything, Just a bit of a way to put off uni work.
You will find that you cant do CFD modelling without a thorough understanding of fluid mechanics. In making the model you have to have more then a basic understanding of what is going on if you are hoping to get accurate CFD results. The old story of shit in shit out...the packages are not smart enough to allow non scientists/engineers really exploit hwat can be done.
I did CFD at Uni in my final year of study, and hated it, because whilst i love the modelling i hate fluid mechanics :cool:
I found FEA is a little easier to use, partly because my mechanics is better then my fluids but also the software packages are a little smarter as stresses are far simpler then the head fark that is fluids >_<
If your studies are related to CFD then you should consider doing it professionally, especially if you enjoy it. Its quite a specialty skill that woudl be great to cruise the market place with
I did CFD at Uni in my final year of study, and hated it, because whilst i love the modelling i hate fluid mechanics :(
I found FEA is a little easier to use, partly because my mechanics is better then my fluids but also the software packages are a little smarter as stresses are far simpler then the head fark that is fluids :bunny:
Yeh I didn't mind the fluid mechanics I did. Was a slight pain in the ass but it wasnt too complex. You are 100% right about needing to know more about fluids then just chucking in some air in and pushing run. What exactly did you study?
I dont think we have a CFD option in my degree at all, hence why I am just tinkering on the side. I deal a ridiculous amount with fluids in chemical engineering with liquid vapour equilibrium, polarity, viscosity, specific volumes and how pressure, temperature, volume, work, and heat transfer affect a system dynamically. But we havent gone too in depth into the fluid mechanics though sadly, that is more of the mechanical engineering side of things.
As for a specialty skill that does sound like a good idea, although I am not 100% sure how much that would be used around here in the mining industry. If I managed to get work with a petrochemical company then Im sure they would love me for it. I guess CFD would definitely be a little notch on my resume. :)
Edited by Lukas 33
  • 9 months later...
I just finished downloading solidworks and dam that thing is....ummm detailed!!!!! I'm with STR8E....tafe course sounds like a good thing
There are tutorials included. TAFE is overkill unless you are going to be using it professionally and need to know different standards. Do the tutorials and just mess around drawing random things and you'll learn enough to make up some fairly detailed parts.
I have been using it as a digital and versitale drawing cabinet lol.
Hicas eliminator (r33,r34,s15 etc) allows normal rear toe arms to be installed and acts as a brace too.
rb25gbox in to silvia...
very handy indeed saves allot of time in the design process allows everything to be stress tested pre fabrication.
to the OP
find download the game STREET LEGAL (the first one) then download all the patches n mods n what not..
then import all your creations for teh awesomeness
its pretty much a game that you can get in to and change shit, you can import things created in cad and what not. im talking everything, wheels, exhausts,engine bits! its epic
  • 1 year later...
just to give this thread a bit of a move on....here is of my first ones.
RB26 exhaust manifold flange with loft from port outline to ID of steam pipe to save a massive amout of die grinding and assist with port alignment and without lofting to keep costs down on cutting, 2axis vs 5 axid for lofted version
    • If there's a next time, next exit after mine is Costco 😛
    • OK. But what about parts of the block that, when assembled, were twisted into a position that pushed into the void space, which, when disassembled, then released that force and opened back up, thus putting the grout into tension? Would effectively just pull the cast iron off the grout at the interface, leaving a tiny void and benefitting not much at all. Swings, and roundabouts. It's like putting something tiny into the fleshlight and finding out you needed a smaller one, to perhaps follow your area of expertise.
    • Nah. You buy a kit that has shorter tubes.
    • I didnt present too many conclusions because I wanted your opinions and feedback based on your own experiences. I don't know the exact material, but it is similar to concrete and therfor only has valuable strength in compression. The forces on the set material once the head is removed would mostly be in compression since the grout wants to retain its shape and the block wants to return to its relaxed state since it's still within the elastic region. The grout would theoretically make the block more rigid. The exact amount would take a better setup on my end. Thought experiment: Instead of aliens, twist your favorite fleshlite. Now fill it with grout and allow it to sit for a week. Now try to twist it again. Observe what you see. Now get your other one and blow into it. Observe what you see. Now put it into a can and fill the space between your fleshlite and the can. After it sets blow into it. Less movement in torsion and less expansion i hope.
