Wrecking R33 S1 Turbo Manual
Wrecking my 1995 R33 series 1, its turbo Manual,
Located in Adelaide.
this car is not damaged at all, it has been defected.
Engine - $2500
Gearbox - $500
3" exhaust with resinator and cat-back, would only be about 6 months old $400
Front mount intercooler $300
Headlights - Pair $250
Spare wheel - Space Saver - $30
18 inch Lenso Wheels - Multi Stud - about 50% tread - $500
Turbosmart BOV - $70
Whole trims for $250 or PM me for individual pieces and i will let you know a price
Front guards $150 Each
Boot lid with spoiler - $120
Brakes and 5 stud conversion - $800
Doors - $150 each
Bonnet - $100
Taillights $300 Pair
Cluster $70
King Springs - Low - $200
Grill - $100
Headlights - $250 Pair
Complete Boot Carpet - $100
Mirrors - $50 Each
Parcel Shelf - $50
Sunvisors - $50 Pair
Climate Control Unit $50
Floor Mats $40 for 3
Heater/ Air con Box $150
Rear Window $150
Front Windscreen $150
Piece on back of car thats got 'Skyline' written - $50
Centre Console $50
Glove Box - $50
Dash $100
Driver seat - has a rip on side and a mark on it - $80
Passenger Seat $100
Indicators $50 each
Driver window switch $100
Passenger window Switch $50
Door Windows $50 Each
Control Arms $40 Each
Castor Rods $50 Each
Manual Tailshaft $150
Fuel Tank $100
Diff $300
Drive Shaft $60 Each
Will post anywhere at buyers expense.
If i have missed anything that you need, PM me with it and i will give you a price, or give me a ring or text on 0432 317 281
Cheers Jared.
  • Replies 41
Engine - $2500
Gearbox - $500
Doors - $150 each
Bonnet - $100
Cluster $70
Grill - $100
Mirrors - $50 Each
Parcel Shelf - $50
Rear Window $150
Centre Console $50
Glove Box - $50
Dash $100
Passenger Seat $100
Indicators $50 each
Fuel Tank $100
Diff $300
Cheers Jared.
do u stil have engine mounts
 Share
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
    • Id like to race in the US i think alot of those track would suit me   For the s15? Youd be stuck between club sprint and the new Open Am wouldnt you depending on how much interior you have left in
