  • Replies 40
  • 3 weeks later...
Greddy Plenum & Injectors are SOLD....
Everything else is still available... Make me some offers guys...
Do you still have the oil cooler kit, and as stated in previous posts, does it come with the relocation for the filter..? Cheers...
  • 1 month later...
  • 5 months later...
ok guys its been a while and I havent put much efforf into selling this stuff but I really want it gone now.
I basically have a complete car minus the plenum, injectors and the power fc.
Will be open to any offers on any parts or willing to do a good deal if someone wants to take the lot.
  • 4 weeks later...
  • 4 weeks later...
Hi, i am faced with the same decision at the moment, whether or not to part out my skyline because i have a cracked head, I want to keep my 33 though, so i would love to buy the cylinder head you had for sale that is if you still have it, i will put down a three hundred dollars deposit and am willing to pay 1000 if you post it, this is just an offer so feel free to fire away with a counter offer
text me on 0417670410
Joel
Its been a hard decision to make but I cant afford to spend any more money on my car and need to part it out.
Apart from the Turbo kit everything listed here is practically brand new. I had only just finished installing this stuff on my car and was in the process of getting it dyno tuned when we ran into problems.
It was either pull the engine again or walk away....
With the tune only ¾ complete this combination of parts made just over 300rwkw...
All parts have come off an Nissan Skyline R33 GTST (Series 1) and are located in brisbane & everything listed is still currently installed in the car.
300+ rwkw Turbo / Intercooler / Intake Kit - $5000
ok this will suit someone who has a fairly standard car and is looking for big power.
I made just over 300rwkw with this setup and want to try and sell it as a complete set. This kit is made up of a combination of new and 2nd hand parts.
If I don't get much interest I'll consider separating the parts at a later date.
  • HKS 3037 56t .86 Turbo
  • HKS Standard 50mm External Wastegate
  • Custom Exhaust Manifold – Ceramic heat coated
  • 3.5' split dump pipe.
  • Q45 Throttle Body
  • [NEW]600x300x76 Hybrid Intercooler
  • [NEW]Trust Type R BOV
  • [NEW]Genuine Greddy Intake Plenum – Powder coated Black.
  • [NEW]Custom throttle cable to suit relocated throttle body
  • [NEW]Custom intecooler / intake piping to suit
  • [NEW]All Hoses / Clamps / Silicone Joins to suit
RB25 Head - $1400
This was only recently reconditioned and reassembled by Colin Lloyd Headsense. Again I want to try and sell this as a complete setup but may consider separating at a later date.
All components are basically brand new and have only been used for a total of 6 hours on the dyno since rebuild.
  • Tomei 256 8.5mm cams
  • Tomei 8.5mm Valve springs
  • New guides & Retainers
  • Ported intake and Exhaust
  • HKS CAM Gears
  • Cam covers have been powder coated gold
  • Greddy Oil Cap
Power FC & Hand Controler - $1300
practically brand new – only just installed and used for a total of 6 hours dyno time.
Kakimoto Regu 06&R Exhaust & 100 cell high flow cat - $1000
Apexi AVC-R - $400
Oil cooler Kit - $250
ISC Radiator - $250
Set of 6 Nismo 740cc injectors - $700
Q45 AFM - $200
2nd hand but in excellent condition
Z32 AFM - $250
Comes with Tomei plugs - practically brand new – only just installed and used for a total of 6 hours dyno time.
More items still to come.
If anyone wants to make an offer on the whole car complete send me a PM.
Photos to come...
  • 3 months later...
Ok guys i still have a lot of this stuff and it needs to go.
Willing to consider any reasonable offer.
RB25 Head
  • HKS CAM Gears
  • Greddy Oil Cap
HKS 3037 Turbo Kit
Oil cooler Kit
The rest of the car is pactically complete so if someone is looking for a good base for a project i am open to offers on the whole lot... S1 R33 and plenty of good condition performance parts
  • 5 weeks later...
  • 1 month later...
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
