The Dr Rebuild Has Begun
I have always been a fan of DR30's, (Ironmask only). Now that I have one of my own, even a bigger fan. I love the white, it's a very cool colour.
Most of the DR's I have seen on here have strut braces, yet mine doesn't have one? And mine is a little bit unique.
Anyone know where I can get some tail lights, you got some D?
DERRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR!
Why would you have a need for a STRUT BRACE when you have a full cage welded into the car????????????????????????????????
Show some intelligence Carolyn, or do you think we are just a bunch of hicks on this forum.
Saying what you have shows your lack of respect.
At least you don't own or have bought the abortion Gavin Strongman has.
"Why do you ask about tail lights?"
If you have the Australian S2 tail lights as I think the car has, it is how it finished it's racing career, or do you plan on having a bastard like your mate Gavin??????????????????????????????????????????????????????????????????????????????????????????????????
D
D
Just start new topic on the classic skylines main page and we can drool from there!
Gavins car is still a ripper to me, really needed some TLC to get it back to 'original' state
sorry for the rambling, im vegetated for a few days from major surgery
Will do, got some great pics, and story.
Gav's car is what actually started my purchase Ideas for this car.
Hope your OK matey, major surgery sux.
  • 1 month later...
  • 1 year later...
I was wondering when I would see this thing again, I was the first Aussie owner :)
The previous owner actually left a Willans harness in the boot, still looks new...I still
have it if your interested! Its looking good, nice one :)
 Share
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stop on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, you need to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
    • Ultimately, if the tip is not far into the runner and the o-ring seals, then you are in business. Have you applied pressure to it as is? It is not really a problem for the injector to twist once it is bolted down, the oring seals it and you don't want it jambed into the oring too hard The plenum is intended to take multiple size lower injectors with different adapters, but the way you have it is fine if they seal.
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
