id say they are still trying to work out why the main caps keep fretting.
good luck.
Another option will be available in 4 weeks from another company that are full counterweight (12) instead of 8. Sweedish highest quality 4340 billet steel forged, finished and balanced in the US.
Edited by Swiper the Fox
Hi guys,
I don’t get on here much anymore. Someone informed me I should make an appearance on this thread.
These forums are a brilliant source of information, a wealth of knowledge and a great place to express your interest in all things automotive , but they also harbour a lot of misinformation, accusations and innuendos.
So if you have any queries about this topic just email me direct, its easier.
Now there has been a big delay with the first trial engine due to incorporating a trial billet main cap design at the same time. Will post pics later today.
These caps require tunnelling boring and the machine shop that did it for me the 1st time made the tunnel a couple thou too big, so it had too go back and be modified. This all has taken a lot longer than expected.
Anyway I have only just received the block back last week so assembly will start soon with the prototype crank etc.
In the process of designing this setup I have decided to make 2 kits available – one will be 95mm and the other will be 93 mm. As the 95 mm stroker does require some block clearancing and isn’t a straight drop in kit . The 93mm crank is going to be full counter weight and will be an easier install.
Both cranks will be available by them selves or in a complete kit with rods and pistons to suit.
These things take time and I am more anxious than you guys to get this finalised as there are numerous other cranks I have in mind to stroke.
I know my pricing will be extremely competitive so hang in there if your interested.
Brad
[email protected]
Edited by Spoolup
Hi guys,
I don't get on here much anymore. Someone informed me I should make an appearance on this thread.
In the process of designing this setup I have decided to make 2 kits available – one will be 95mm and the other will be 93 mm. As the 95 mm stroker does require some block clearancing and isn't a straight drop in kit . The 93mm crank is going to be full counter weight and will be an easier install.
Brad
[email protected]
no accusations and innuendo Brad...just guessing what may have been happening as im quite aware of what you are trying to achieve and the pitfall associated with it. Good to see you back with some news for interested parties after a couple of months absent...so the crank you have pictured on your website is not actually the correct design as the picture is of an eight counterweight item...its a little confusing.
Couple of thou out and two months plus to rectify...id sack your machinist as thats pretty crook. If you want to use a decent one PM and ill give you some info on who you could use.
Personally id ditch the 95mm item and put all your effort into the 93mm one as the 95mm is going to be a cluster fu(k to get right.
Paul - I wasnt just directing my comments to you, but in general.
The crank in the pics is one of the trial 95mm stroke cranks I have - its actually quite easy to install just not a direct plug and play.
The tunneling boring issue was done by someone I dont usually use - as your aware not alot of places offer that service so I had to go to someone else.
The guys I use for all my other machining are slow but extremely pedantic and it would take alot for me to change.
Where are you situated ? as I am in Qld ?
As soon as I have this trial engine assembled and running etc, and Im happy with the install and worked out all the bugs, both cranks will be produced available in full counter weight.
At present Im still confident the 95mm, 8 counterweight cranks I have will work fine for what they were designed for.
Edited by Spoolup
OK things are all good from both ends then...sweet.
Im in the exact same position as you in regards to machine shop...my guys are craftsmen but they have a slow and steady approach...gets a bit frustrating sometimes but better than having to send stuff back due to rough tolerances...if its not exact it doesn't leave their shop. I have to send tunnel bore jobs to Sydney (we are in Newcastle) as their is little demand for the work up here to justify the huge outlay for quality machinery to perform it correctly (im actually off to sydney tomm to personally oversee an N1 block be fixed).
Are the cranks finished here in Australia? and where is the parent material sourced from?
Im keen to know more details on the full counter 93mm crank, as Paul said above what are they made from, and are the billet caps going to be availiable to buy or are they a 1 off?
Cranks are made of billet 4340 - manufactured and finished in China. Same as the conrods I sell
I have the steel analysed on a mass spec here in Aus in a NATA certified lab. It always meets the 4340 std.
Sizing is checked here in Aus also.
The majority of conrods and cranks in the world today are made in China.
Yes the billet caps will be available also as a kit - they are made here in Aus.
Argos are made in Aus
Eagle, Scat, Brian Crower, some of the Jap brands are made in China - Paul and I have had this discussion before :-)
Not many pistons are made in China - yet
That is interesting most conrods are made in china, I guess they've picked up their game?
Paul - where are argo rods made and mahle pistons?
just get an r35 which has the vg38 & be done with it HA!
VG38? do you mean VR38?
besides, i like the sound the RB makes :3some: so its good that we are seeing development along this path. i think one day someone will shoehorn the VR38 into the 32,33, 34 skyline body - but just think of the cost!!!
u know what i mean :3some:
maybe the 32gtr will become like the classic datsun 1600 where ppl are squeezing sr's & fj's into them lol
u couldnt do that to a japanese supercar which hit the market @ 125k back in 89...i wonder what the value of 125k 20yrs ago would equivalent to in todays market?
anyway, waaaay off topic now, sorry brad.
the caps look like they are seperate from the girdle....any reason for this?
I would say because it would cost about 1/5 of the price to manufacture. while still retaining the strength esp if there Capscrews that are holding the 2 parts together.
Regards
Chris
Yes it basically comes down to manufacturing costs.
Regards
Chris
pics of main caps
WOW, you have balls posting pictures of something you have clearly just copied from me!!
Maybe its OK in China to copy anything and have no shame or morals about it but I sure didn't expect it from you.
Stop any production or use of those mains caps immediately and I hope you have a good lawyer and best you get him to get in touch with me smartly.
Rob
Rob, not trying to be a smartarse but even if these caps look similar to your ones can you stop someone else producing a 'similar' product ?
Or are your caps and design patented ?
 Share
