THREAD CLEANED AND LOCKED
Spoolup; Feel free to start a new thread with info etc about your product when you are ready in this section. Any off topic posts I see will be deleted so it stays clean and factual for you.
Ripsnz; if you have anything to say to spoolup, I'd suggest email/phone/PM the best way to do it.
Spoolup and ripsnz; Youre both welcome here of course, your contributions are always valued.
All other users; Everyone is entitled to their opinion, but this is not the thread to have your speak out. There's other threads, and if what you want to say isn't an existing topic, feel free to start one as long as it's within SAU rules of course.
Guest
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
