Hi guys,
Have the following for sale. All items are in Adelaide, SA. Pickup preferred, unless you want to organise postage / courier.
17 inch Tyres + Rims
4 x Yokohama Advan Sport V103 (255/40ZR17 94Y) very good tread $800 (+$1600 new!)
4 x Bridgestone RE55s (255/40R17 94W) a couple of track days left in them $400
4 x Bridgestone RE55s (255/40R17 94W) 60 - 70% tread $800
4 x Dunlop V8 Supercar Slicks (280/680R17) 40% tread $400
4 x R33GTR Rims only with centre caps, reasonable condition a few marks $1100
RB26 Engine bits
Greddy Carbon Engine Cam Valley / Timing Belt Cover $300
R32 GTR Aircon Setup (everything aircon forward of the firewall, excellent working condition prior to removal for weight reduction) $100
Trust MX Front Pipes (goes from dumps to cat) dent in standard spot $250
RB26DETT Plenum / Inlet Manifold / Exhaust Manifold (6 Total) Gaskets Brand New $40
R32 GTR Clutch Slave Cylinder (good condition, upgraded to nismo oversized due to triple plate clutch) $40
2 x AFMs excellent working condition mesh not removed (removed due to D-Jetro) $100
RB26DETT standard dump pipes $50
Jap retuned standard computer (no speed cut, car made 270rwkw with standard engine/ turbos etc and this computer) $300
Misc
Nismo genuine boot spoiler internal damage but should be repairable $50
Earls Oil Stat – installs into oil cooler circuit to thermostatically control oil temp. Dash 10 fittings for easy installation. Also has ports for oil temp and pressure senders. See http://www.earls.co.uk/earls/catalogue/Cooling%20Systems.pdf PART # 501ERL $200
R32 GTR Silk Road Coilovers typical hard jap spring rates $400
Sub Box, fits 2 x 12 inch subs in R32 boot WITH rear strut brace. Made from 16mm MDF, including fittings $50!!!
R32 GTST Type M Driving lights fit in Type M front bar $50
RB25DET Alternator and Aircon Compressor Good condition $50 each
Low Ballers will be ignored, genuine offers considered. First in, best dressed and items not considered sold until payment received or pickup arranged. Get in on some bargains and help de-clutter my garage! Postage at buyers expense.
Pics will be put up tomorrow as 40+deg in Adelaide today = to hot to go in the shed :)
Cheers,
Andrew
Blue32
  • Replies 52
ALSO ADDED:
R32 GTR genuine intercooler mesh $50
Rubber inlet boot RB20 / RB25 $30
R33 RB25DET airbox and snorkel including filter $50
Pioneer GEX-6450TVP - watch TV on your incar pioneer DVD player. Including aerials etc
R32 GTR Aircon Setup (everything aircon forward of the firewall, excellent working condition prior to removal for weight reduction) SOLD subject to payment / postage thanks nismo32GTR
Couldnt write pm to you as your inbox is full. PM me your mobile number
would you do $35 for the mesh? Im in SA so no mucking around with postage.
Cheers!
Tried sending a pm but said you inbox was full?
How much for the Carbon Vally Cover by itself delivered to Sydney
Cheers Brian
Sorry I would like to sell them as a matching set - unless there is someone who would like the timing belt cover?
R32 GTR Aircon Setup (everything aircon forward of the firewall, excellent working condition prior to removal for weight reduction) $100 SOLD Thanks Nismo32gtr
R32 GTR genuine intercooler mesh $50 SOLD thanks R32Abuser
whats the boot lip spoiler made out of? is it for an r32 gtr because im planning to put this on in addition to the standard wing.
thanks
thanks
It is the original rubber nismo boot spoiler for R32 GTR with metal internal frame which has some rust damage. It is designed to fir under the standard GTR wing. With a bit of work it shouldn't be too hard to return it to its original state and refit it netting a very cheap original spoiler (not fibreglass etc as they tend to be these days)
Edited by Blue32
would you post to 3064 in Melbourne? if so how much is postage?
$35 delivered to your door - it is too big for Aust Post. I'll do it for $80 delivered.
    • Crazy how good the aero bar looks compared to the stock one
    • Yes, but you will need to rewire all the things that are different. CAS, coils, etc. Yes, but there is no IAT. What? You can use anything you like. It just has to be hooked up so that it will work.     Or are you wanting to just plug and play without having to do any thinking/work?
    • It's been a little over a decade since I bought the S15. As I did on my socials, I'll share some of my favorite pictures from over the years further below. If you haven't realised, pretty much all the pictures in my posts are ones I've taken.  In terms of updates, I don't have pictures, but I acquired a near-perfect pair of fog lights from a friend of mine, so those got swapped in for the pair I already had. As for the JZX110, I just got it back from being fixed. A few weeks back, I was on the highway when I suddenly drove over something with very little time to react. It was probably the size of a soccer ball, but it went under the car and banged into the underside pretty loudly. I pulled over and realized the fluid leaking was fuel, and of course, it was right near my exhaust. This required replacing the fuel tank. If you happen to be in the same predicament, thankfully this car shares a fuel tank with the JZS171, IS200, and IS300, so it wasn't too painful to replace. Enjoy some pictures as mentioned above, including the carnage from the fuel tank and a bonus picture I came across which shows how ridiculously shiny the Bugels are on the 110. So many more pictures I could share of the S15 but this will do for today, enjoy.
    • Welcome.  Was the mistake the car, or joining us? 😏
    • Yeap, was me and the daughter getting coffee before heading to the new joint to measure up the fridge space and taking some pics that the solar installer wanted of the switch board
