  • Replies 71
Dont take this the wrong way, but 160k car, $80 stands, ive seen them break
I certainly wouldn't creep under a 1800kg (less 4 wheels!) car standing on 4 matchsticks.
That is exactly how my wife became an orphan at 8 months.
Sorry mate, you should think of your beautiful son, it's not worth the risk!
Edited by GT-Ricer
https://www.sau.com.au/forums/topic/303133-my-r35/page/2/#findComment-5028993
I already mentioned you should use the floorjack as a backup on the front or back. What kills people in this situation is... no backup / SINGLE point of failure. 100% of the time.
https://www.sau.com.au/forums/topic/303133-my-r35/page/2/#findComment-5029107
Good luck with the project!!!
What are your reasons in choice of pads? Endless, Project Mu, Ferodo, etc...
I am going with AP rotors and some Hawk pads. No great science/research on my part i am just going on a recommendation from a friend who is around brakes + race cars as his job. See how it goes i guess.
https://www.sau.com.au/forums/topic/303133-my-r35/page/2/#findComment-5029109
Nice!
Let us know the result in the difference of the pads and rotors, stock to aftermarket.
https://www.sau.com.au/forums/topic/303133-my-r35/page/2/#findComment-5029955
Duncan your a brave man to be tackling this project on those stands even with a floor jack as a safety!! Good on you dude.
Ive done the AP J hook rotors, Carbotek 12 (yeah they squeal like a bitch) and Stillen braided lines and now the braking is simply amazing. The pedal has so much bite that it just hauls the car down from 200+ to 50 in a couple of seconds. If you have a spare $300 get some stillen braided lines cause when i compare my brakes to 09 GTR who has the similar set up my pedal is def stronger which would be good for your sprints.
Edited by White 35
https://www.sau.com.au/forums/topic/303133-my-r35/page/2/#findComment-5032822
Duncan you have inspired me to harden up and screw the nissan warranty in view of some track work this year
I think it's great guys getting into the track work and basic maintenance themselves :thumbsup:
this thread got me thinking what I would do when I have a tool around under the car next month
I have on order some 5T truck jack stands (pin not ratchet) for work with the wheels off and some wooden blocks for under the wheels
similar to below for whilst working under the car. will let you know how I go when i get my shite together
https://www.sau.com.au/forums/topic/303133-my-r35/page/2/#findComment-5034117
ok so tonight whilst the car is up on stands i thought i should get the carbon air intake installed, sometimes i wonder why i get into doing these things!
but here we go......... (better be worth it)
Martin where is my updated tune! lol.
Edited by LSX-438
https://www.sau.com.au/forums/topic/303133-my-r35/page/2/#findComment-5035360
Dunc,
Hats off to you mate, it is at this point I would have another kidney tray with a whole range of nuts and bolts that are left over and I am not sure where they go.
Thanks Gibbo!
Not finished though! still got a bit to get through before the first round this sunday, going to tackle these tonight...
Yes, have a stripped stud or two AGAIN as well :( plus new j-jooks and pads
https://www.sau.com.au/forums/topic/303133-my-r35/page/2/#findComment-5036588
Some of the bolts and plastic clips are getting a bit worn, so i had to source some (for the various covers atc under the car) thought i better do it whilst they are all off the car now. This is what seems to work (see pics also):
M8 x 16mm
M6 x 25mm
I picked up some high tensile ones as that is all i could find, however i am sure you can get some regular ones cheaper. The bolts are about $4~$5 for a box or 5 or 10. I noticed some of the OEM bolt heads were a bit scratched up and i couldnt use the socket on them (too damaged) so perhaps the high tensile ones wont disentegrate so easily? i dunno we'll see.
I sourced the bolts from Supercheap (i guess you can get them almost anywhere) and the plastic clips (not sure what they are called!) from JustJap in Sydney.
https://www.sau.com.au/forums/topic/303133-my-r35/page/2/#findComment-5036611
Because jack stands just brake everyday and all 4 fail at the same time?
You can't be serious.
I had a bunch of dramas today, snapped caliper bolt!!
How'd you manage that, did the jackstand break on it?
Edited by GHOSTrun
https://www.sau.com.au/forums/topic/303133-my-r35/page/2/#findComment-5038690
    • That's right, simple but works. Run out of load? Rescale the table lol. Want to be lazy and not rescale? Drag the K
    • @DraftySquash @Duncan he's not talking about the part that sits against the radiator support, he’s talking about the lip that sits towards the front outside of the car. anyway I had a look at other cooling panels and came across this one https://justjap.com/products/carbing-radiator-cooling-panel-plate-nissan-skyline-r34-gt-t?variant=37829684134087&currency=AUD&utm_source=google&utm_medium=organic&utm_campaign=Advanced feed&utm_content=Carbing Radiator Cooling Panel Plate fits Nissan Skyline R34 GT-T (Coupe)&srsltid=AfmBOoonzPDKqe9NgKi5U0AkFc2XvbXETGmNWvfNcyBT5DUZagMYHg9DZ70 if you take notice it’s the same shape.  well thankfully the justjap listing has a description and it says : - Nissan Skyline R34 GT-T Coupe (M/T -07/2000) this means it’s specifically for a s2. S2’s have different front bars to s1 so that lip with the 3 holes are *probably* mounting points for the s2 bar. im not 100% sure but im almost certain it will still fit a s1 bar
    • Everyone is too used to learning from places like HPA "how to tune" and what to expect at what point, rather than being able to see "The computer says I'm in cell with Row = 8, column =4, and I can see my fuel is lean, so lets add more" Everyone wants "real units", which helps for someone picking it up for the first time and seeing how bad the tune is if they're not used to touching it.   However, I think for most of us who want to play with it, you're 100% right, we're only needing to learn about it for OUR CAR. Which makes it great, and we don't need to care what the real values are, we just need to know which cell it is, that's causing the lean or rich point, or that we want more ignition timing or less. But again, everyone wants everything super you beaut and nearly self tuning, with VE maps, and a billion compensations...   Though then there's me over here when I'm doing reverse engineering work just reading data in hex format that most people couldn't work anything out from. Yet I can see what's going on.
