  • Replies 71
I don't think the problem is so much them braking, but the whole car on 4 skinny posts with fairly small base could just topple over sooner or later.
Regardless, knowing you are a careful man I still congratulate you on the effort. There is nothing quite as satisfying as working on your own car.
https://www.sau.com.au/forums/topic/303133-my-r35/page/3/#findComment-5039312
Because jack stands just brake everyday and all 4 fail at the same time?
You can't be serious.
How'd you manage that, did the jackstand break on it?
The caliper bolt just broke undoing it. Perghaps it was seized a bit. Nothing to do with the jack stands!
https://www.sau.com.au/forums/topic/303133-my-r35/page/3/#findComment-5039587
trust all went well
how were the new rotors and pads?
I had a shocker of a day yesterday (last sprint at OP) the slicks were just not working, there was little grip. I was running about 1 second slower than last time i was there (with RE55's) so i am not sure what to say about the brakes yet; i just couldnt get into a groove and was focused on other things.
I will say that the j-hooks are rather noisy though, you wouldnt go for them unless you are chasing track times i reckon. Sorry, hopefully i have more meaningful feedback after the next track day.
https://www.sau.com.au/forums/topic/303133-my-r35/page/3/#findComment-5040032
Awesome - you could see a smoke out the drivers window. You reckon it had something to do with you putting the suspension setting to softer, if I'm not mistaken, as you were going down the straight..
I was actually turning VDC Off. Lately i've been running the outlap with it on for a bit of cold tyre safety. Probably a waste of time. Anyway all my PB's are with VDC off (you can't run your quickest with it on). The car wouldnt have done that with VDC on. I was just over-driving with cold/worn slicks simple as that i guess.
https://www.sau.com.au/forums/topic/303133-my-r35/page/3/#findComment-5043382
Its an easy analysis after watching the video Dunc, that neat little tip in wobble to settle the front is now gone, as the front doesnt bite, which then causes you to lift the gas, then step back on it, which unsettles the rear, which also doesnt bite. No grip - time for fresh Michelins :)
https://www.sau.com.au/forums/topic/303133-my-r35/page/3/#findComment-5043419
totally unintentional! the tyres just were not working (dunlop slicks). I have some video i will post up soon (equally sloppy) but gives you an idea
in my experience with a porsche cup car the michelein slicks are much better than the dunlops. we always run the micheleins but one or two events had the dunlops as the category tyre so we had to use them and were about a second off the pace on them.
https://www.sau.com.au/forums/topic/303133-my-r35/page/3/#findComment-5044461
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
