Have just purchased first skyline and i'm not sure if the boost gauge is reading right, it generally sits in the negative and only goes into positive boost when accelerating hard, is this normal?
That's what its supposed to do?
That is the corect operation of a boost gauge. Under no load the intake pressure sits in a vacuum, demonstrated on the gauge as a negative pressure. Once the engine is under sufficient load and the turbo is "spooling" the pressure will go into a positive "boost" it will continue to climb until the wastegate cracks open and the boost will stabilise at a single value controlled by the wastegate/boost controller.
Have a read of this, good article to explain the basics.
http://www.howstuffworks.com/turbo.htm
Edited by PM-R33
k, cheers for that i also wanted to check just below and to the left of the steering wheel there is a screw with a black cap on it that dosen't seem to do any thing is that just for securing some sort of access panel?
another question, is it common for the exhaust manifold nuts on cylinders 1 and 6 to come loose/ fall off, and is there a special nut/washer type to stop this?
Totally normal.
Just kidding dude. Maybe the studs are broken so they arent staying tight?
Best thing to do would be to find new ones and just put them on tight.... tight tight. Maybe even some threadlocker?
Standard gauge isn't the best. Check the line for it hasn't cracked as they tend to do. It comes off the intanke manifold near the firewall, it's a 4mm black rubber hose
I had this issue. The rubber hose becomes brittle and cracks appear which messes up the factory boost gauge. I had some 4mm rubber vacuum hose lying around which I installed and all is fixed with the gauge. Very easy to fix.
Yep, I had the same trouble. That little hose just gets brittle with age. Also causes a vacuum leak, which harms the boost as well.
A few bucks worth of hose from Autobarn should do it!
  • 4 months later...
hi.. thought i would post here.
this hose for the stock clusters boost gauge, has came off, its still connected to the manifold, but it has came off at the other end, i pulled it and it came from behind the drivers guard.. so while ive had my guard off today, i have been trying to reconnect this, but i cannot find anywere it goes?, can some one lend a hand to were this connects back.. thanx
    • Breather for it. If it's anything like the GTRs it should run up to the top of a bellhousing bolt.
    • What basics? With these OBD1 ECUs it's not like the ECU will give you any real clues, it's not really doing any sanity checking of sensors/sensor data. My experience is actually a lot of sensors tend to be the source of the issue first and foremost, and checking everything gives you a direction to investigate. MAF/O2/STFT/LTFT should all kind of make sense. You can try little tricks of the trade like tapping the MAFs to see if it triggers a stumble, things like that. But once you've done a compression test knowing whether you have an air leak or fuel delivery problem is kind of hard to narrow down without sensor data. And you don't really know if all your sensors are making sense unless you can interrogate the ECU directly about what it's seeing for sensor data.
    • Absolutely this. Yes, except not vacuum hose. Something oil/fuel safe is a better idea.
    • Like a Stagea, but not as cool! Hope you have enough garage space for this, or is something going to leave to make way for it?
    • The new project has arrived. I have wanted one of these for such a long time, well before that meathead Clarkson drove one in Africa. I really wanted an E34 but I have some medical issues that mean I *really* can't bump my head and the lack of airbags in the E34 made it just too big of a risk.  I don't know why I've always liked these older touring BMW's to be honest, but man I love this car. She's been pretty well maintained for her 243k's with what appears to be only a single oil leak at the oil filter housing gasket. It has a bunch of updates including later model bumper and headlights, 7 series billion-way adjustable seats and it came with a few spares and another set of wheels with legal tyres. I got a unregistered car permit from the RTA and drove it back from Canberra on Saturday.                   First cab off the rank is cleaning it up for blue slip. I dont know how picky they'll be but I figured I'd clean the headlights, fix the oil filter housing gasket, replace the speed sensors (throwing errors) and swap the OE wheels (the M Sport wheels have a big chunk out of one of the tyres.) I also need to replace all 6 gas struts - 2 for bonnet, 2 for hatch and 2 for hatch glass. The car tries to eat me whenever i open any of these. My plan for this car; Ultimately, this is a budget car. I can't afford to throw lots at it and its because I have another car that I got this, if something breaks its no big deal. I will just maintain and repair it really. But eventually I want to do a manual conversion. It actually looks pretty straight forward for E39's and the trickiest part will be sourcing the parts.  I do need to replace some suspension arms or bushes because wow, she's a floaty old girl. She's also fantastically slow. Like really, really slow. When pulling back out on to the freeway on Sat after a quick pull over I needed to wait until no cars were visible before going.  Oh, and the guy I bought it from had a gorgeous R31 GTS-X in the garage.
