Hey Guys,
just hoping someone might have some idea on a problem I'm having.
On holidays, jumped in the car this arvo and car wont start. Cranked a little at first then nothing.
Reds come on then nothing when I try and turn it over.
I can here the fuel pump prime.
I cant here any click from the solonoid and its a little hard to get to in the dark to try shorting it.
there have been a couple of times in the last week when it seemed slow to crank over, I tried to jump it but no go.
any help would be appreciated
cheers
Gerard
https://www.sau.com.au/forums/topic/303139-help/
did it make clicking noises??
no clicking noise.
electrics do come on but no cranking.
Had a similar thing on a telstar once which was the battery even though the lights and reds still came on just wasnt enough power to crank??
https://www.sau.com.au/forums/topic/303139-help/#findComment-5025132
See my thread re starter problems but if its cranking but slowly then it won't be that.
Try a jump start from another car to get you going.
Starter on the way out will draw excessive current ...so you need to test the battery condition, alternator output and starter draw - so that probably means a visit to an auto electrician.
https://www.sau.com.au/forums/topic/303139-help/#findComment-5025175
Thanks Bob, went out this morning and shorted it across the solenoid. turned but slowly.
Managed to give the starter a few good hits and it started, so now have to find an auto electrician in Port Macquarie that will fit a starter tomorrow
https://www.sau.com.au/forums/topic/303139-help/#findComment-5025584
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
