Hey Guys,
just hoping someone might have some idea on a problem I'm having.
On holidays, jumped in the car this arvo and car wont start. Cranked a little at first then nothing.
Reds come on then nothing when I try and turn it over.
I can here the fuel pump prime.
I cant here any click from the solonoid and its a little hard to get to in the dark to try shorting it.
there have been a couple of times in the last week when it seemed slow to crank over, I tried to jump it but no go.
any help would be appreciated
cheers
Gerard
https://www.sau.com.au/forums/topic/303139-help/
did it make clicking noises??
no clicking noise.
electrics do come on but no cranking.
Had a similar thing on a telstar once which was the battery even though the lights and reds still came on just wasnt enough power to crank??
https://www.sau.com.au/forums/topic/303139-help/#findComment-5025132
See my thread re starter problems but if its cranking but slowly then it won't be that.
Try a jump start from another car to get you going.
Starter on the way out will draw excessive current ...so you need to test the battery condition, alternator output and starter draw - so that probably means a visit to an auto electrician.
https://www.sau.com.au/forums/topic/303139-help/#findComment-5025175
Thanks Bob, went out this morning and shorted it across the solenoid. turned but slowly.
Managed to give the starter a few good hits and it started, so now have to find an auto electrician in Port Macquarie that will fit a starter tomorrow
https://www.sau.com.au/forums/topic/303139-help/#findComment-5025584
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
