Hi all.
I drive an r34 GTT, quite stock except of a 3 inch turbo back exhaust, brand new coilpacks, and a apexi power intake pod filter.
Doing this i have not gained any extra boost what so ever, i have an aftermarket boost gauge and it stayed the exact same as when the car was stock, thinking it would creep up with each little mod.
Its kind of like its been set to that setting, which is approx 5.6 psi and is getting stopped at that.
A good friend of mine has the exact same car, except a year older but has a very noticeable difference in power. He has factory coilpacks, factory exhaust but a HKS pod. He is pulling a lot more boost and is really really noticable when driving. Neither of us have touched the turbos or even have boost controllers.
Any ideas why this is, if anything i should have quite a bit more power than him but its the other way around.
Have they come out of the factory with different boost settings??
Are the pods making a difference?? We took his off and you can see light through it and is very thin, mine on the other hand is really compact and a bit like carboard looking.
Appreciate any help guys.
Thanks
https://www.sau.com.au/forums/topic/303145-lost-power/
standard on the cars was 5psi up till 4500rpm then up to 7psi from then on. I have a completely stock 34GTT and wasn't sure whether an exhaust would actually allow the boost to pick up or if the stock controller would stop it from going any higher someone will be able to shed some light
https://www.sau.com.au/forums/topic/303145-lost-power/#findComment-5025183
This stays at 5 right up to red line??
https://www.sau.com.au/forums/topic/303145-lost-power/#findComment-5025210
sounds like a faulty boost control solenoid
Buy a turbotech boost controoler for about $30
Will that automatically adjust the psi??, because id say my mates is up around 7-8 quite easily. and im the one with mods.
https://www.sau.com.au/forums/topic/303145-lost-power/#findComment-5025271
Of your mods, the only one with the potential to increase boost and power output is the exhaust (by freeing up the flow of exhaust gasses). If anything, the pod will reduce power output because the engine is inhaling hot air from the engine bay, rather than cooler air from outside the car.
https://www.sau.com.au/forums/topic/303145-lost-power/#findComment-5025470
boost soleniod will remain off for a lot of symptoms on the trouble shooting matrix in the manual . try re setting the ecu . or re plumb the t piece so its on 7 the whole time . its easy to do and very relaible
https://www.sau.com.au/forums/topic/303145-lost-power/#findComment-5025489
hay mate sound like your having some fun with your car! just a bit of infor for you, when asked to swap cats with your mate this is becouse if your cat, new or old has failed internaly it can cause the exhaust to block this will limit in min or major way how your turbo boost and how much it can boost to (depending on what is wrong) easy thing to check, drop it out and look at it! you factory boost solinod could be then next problem as stated thats easy to check as well change that out with your mates car, and for sh_ts and giggles if thats your problem then go for either electronic boost controlled ( no nasty boost spikes ) or a t piece bleed valve there are heaps of these to choose from most have psi settings on them you can adjust to, without the nasty guess work ( better to be safe then sorry) remember though when re setting the boost level the stock turbo has a ceramic exh wheel so from memory 10psi is max safe limit with out ca-BOOM!!!!!! i could be wrong so resurch this as there are a few guro's on this site, like discopatato for instance.
https://www.sau.com.au/forums/topic/303145-lost-power/#findComment-5025541
what about intake mods? if your air filter is blocking the flow with a dirty/restrictive filter then it wont matter what exhaust you have.
Intake is only a apexi power intake pod filter, cant personally see a lot of air getting through it. Great filter but very resrtictive on the air flow getting through, its like a piece of cardboard.
https://www.sau.com.au/forums/topic/303145-lost-power/#findComment-5025670
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
