* RB25 gearbox - make offer
* RB25 excedy clutch with pressure plate and flywheel (clutch pucks need rebuild) - $100
* R33 GTS-t 3" cat back exhaust (hollow cat) - $300
* R33 GTS-t full body kit, (I'm pretty sure front and sides are 400R) - $400
* R33 GTS-t hybird cooler piping - $90
* R33 GTS-t cluster - make an offer
* R33 GTS-t climate control - $80
* R33 GTS-t rear tail lights including centre "skyline" piece - $60 per light, $40 centre peice, $150 for the lot
* R33 GTS-t rear seats - $80
* R33 GTS-t LHS & RHS doors (complete; including trims, window, switches etc) - $150 each
* R33 GTS-t interior roof light - $20
* R33 GTS-t under door plastic trim says "skyline" - $15
* R33 GTS-t std rear spoiler - $50
* R33 GTS-t rain blocker (sits at top of door) - $30 each
* R33 GTS-t clutch fan - $60
(all from S1 R33)
* 180sx locked diff (recoed then welded) - $200
* 180sx RHS front guard (black) - $120
* 180sx std front bar (black) - $70
* 180sx climate control - $80
* 180sx std fog lights - $10
* Blits blow off valve on hotpipe - $30
* Apexi AVCR boost controller - make an offer
For these parts, call 0422 026 957
Also selling the following:
* R32 GTS-t std dump/front pipe - $100
* R32 GTS-t std cat - $50
* R32 GTS-t std blow off valve - $50
* R32 parcel shelf - $60
For these parts, call 0432 326 673
Edited by dmr
https://www.sau.com.au/forums/topic/303154-r33r32180sx-parts/
Hello,
are the 33 parts series 2? Any chance to send pic of body kit? [email protected]
You dont have a beaver panel do you? Or front bar reo?
Thanks, Danni
  • 3 weeks later...
    • It's been quite the ordeal but hey, at least you figured it out.
    • The final part arrived today to un-clampify and simplify the intake Who would have though a 1/2" hose stainless bulkhead fitting designed for below waterline bilge pumps would be what I needed Test fit on a 3" offcut I had laying around to see if it would work, and it worked a treat All going well the intake will be on its "final version" tomorrow
