  • Replies 67
Going camping this weekend.. will be taking lots of pics for week 5 photo!
Waterfalls... possible star-trails... also taking lots of LEDs along so might get some cool jay019 style shots :happy:
cant wait to see them :D
Matt, it's a ND1000. There is a nice table on the wiki showing how many f-stops and light the different ones let through: http://en.wikipedia.org/wiki/Neutral_density_filter
And as for Project 52: I haven't been slack taking photo's.. just been slack processing them!
LOL. Maybe just rename it to Project 26? :sick:
ND1000! lol, yeah I'm reasonably read up on ND filters just never really considered using them till I saw your shots :sick:
What size/brand and where did you get yours from? I need a 77mm for my canon 10-22 lens
ND1000! lol, yeah I'm reasonably read up on ND filters just never really considered using them till I saw your shots :D
Haha thanks :(
Thought you might not have... as I specified "Photo was taken using ND3 (x1000) filter..." when I posted the photo
I just got mine from ebay. It's a B&W 77mm. Got it for my 10-20, would also fit my 70-200 but doubt I'd ever do that!
nice shots man.
Definatly going to grab one of those filters to have a play with. might wait till i get a 10-20mm lens though. the 17-85mm probably wont cut it for the type of shots you could use it for.
Traditionally they are good for landscape shots - which 17mm would be fine for IMO.
Unless you are going to buy a wide angle anyway - I wouldn't buy a wide angle just for the ND filter's sake.
Maybe check the sizes - you might be in luck and be able to use it on both (unlikly)
however my 10-20 and my 70-200 for example are both 77mm
so I can switch my uv, skylight, cpl and nd between them
Haha thanks. Have an old four wheel drive and love camping. Went camping last weekend at Springbrook. Rained almost the whole weekend :)
But its an awesome spot - lots of walks and its very 'rain-forestry' - so will have to go again sometime!
Yeah springbrook is pretty nice.
That creepy photo from the Feb thread with the girl in the window was from the cabin there at the mouses house..
I'm planning on getting a 10-20mm or similar lens anyway Zennon. as most of the things i enjoy taking photos of are landscapes.
my 17-85mm is only 67mm so i doubt it will fit on a 10-20mm.
I'll Just add it to the enormous want list i have i guess.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
