Hi all, im just pulling my spark plugs out today and noticed the guy who serviced the car has put the following spark plugs in
NGK BKR5E 11
now from my knowledge this means that its heat range is 5 and the spacing is 1.1
my question is, is this ok for a stock (apart from pod filter) RB25DET R33?
if not, what should i be putting in there? can i use the current spark plugs and close the gap? im also having a slight miss firing problem on idle, can this be the reason why?
any help is great ta!
https://www.sau.com.au/forums/topic/303209-quick-spark-plug-question/
NGK BKR5E 11
chutch, I changed mine b4 chrissy and my mechanic said go 4 the 5z. 6z if ya got a few modsand hi boost (12psi+), I think the 1.1mm is OK, Close the gap if ya have misfire probs.
Which plug you use comes down to the mods. I run 5z ($3 each NGKz, changed every 3500km) & have no probs in my R33S2 with a 3" turbo back, pod,9~10psi & mines ECU (just pours more fuel in) , Oh & standard coil packs... Daily driver 2
how was it running b4 you pulled the plugs??
Hany Chart VVV
it was running a bit rough, it would go up and down slighty (the revs) and it also paused the revs like brrrr brrrrrrrrrrrrrbrrrrbrrrrrrrr un eavenly, should i close the gap? to .8 or something? i have no mods apart from a pod
ta
ta
Sounds like the clasic lack of backpresuer in the exhause ??? you said standard but so....
I'd look at plug packs or maybe blocked injecter...
a consult program like ECUTalk/Nissan DataScan would show up faulty AFM's etc, could be worth a look (datascan can shut off each cylinder, you might be able to tell if its one/two pots misfiring(plugpack) or random(sensor)
my exhaust is mostly stock, except the last owner has put a 3 inch pipe after the dump and front pips till the stock axel pipe/muffler, would this cause the no back pressure?
ive run a injector cleaner through, but i dont think there blocked because when your accelorating its fine, it only seems to do it on idle
cluch,
just did a quick search (rough idle) n found these
http://www.skylinesaustralia.com/forums/Ro...=r33+rough+idle
http://www.skylinesaustralia.com/forums/Id...=r33+rough+idle
also check the vacume lines around the turbo & BOV 4 splits and reset the ECU ( they self learn )
cheers bundy
Edited by BundyBear
    • Just a follow-up on this topic. From what I can tell so far the rusty residue on the engine block might be unrelated to a coolant leak or maybe just older than anticipated. After driving it from the winter garage to my friend's garage I could not see any new traces of coolant leaking there, but I will test this properly once I was able to fully warm up the car and drive it for a bit. I think I can agree that the whole porous engine block stuff is kind of nonsense, but there is just a silly amount of true, false and half-true information on anything Skyline-related on the internet.
    • hrmmm , not mine , easter plans to pull engine not happening
    • I removed the IACV, cleaned it and reinstalled.  I found a video on youtube that helped with the whole process, the guy then said the idle needed to be set, so the process was to get the vehicle up to operating temperature, unplug the TPS, set the idle screw in the IACV so the RPMs were around 600, then plug the TPS back in.  After I reinstalled the IACV, the car started (because, it was a cold start), once it warmed up, the car died, I adjusted the idle screw to see if that helped anything, it did not, I had to wait about 3-5 minutes, then the car would start back up. Only to shortly cut out, and only crank.  I loosened the TPS to see if adjusting that would do anything, and when I would rotate the sensor clockwise, there was a humming noise, but it would go away when I got the sensor in the horizontal position.  It only made the hum noise with the key on.  What do you guys think? 20250414_172604.mp4
    • Quick update.  The engine grounding strap was replaced, the engine is now happily running.  Tested the voltage drop before replacing the strap, was about 1.2ish volts down between engine to battery, chassis to battery. With the new grounding strap, pretty much no voltage drop at all.
