R33 GTR V-Spec's had stiffer suspension + a lower ride height.
An updated ATTESA E-TS Pro all wheel drive system + an Active Limited Slip differential (Active LSD).
Four wheel independent channel anti-lock braking system.
The car weighted an extra 10 kg.
If you're looking to buy an R33, you'll notice many of them are Vspec's anyway. If they're modified (which most of them are to some extent), then the differences between the two models become largely irrelevant.
Are you looking to buy one or is this just a general question?
When purchasing my R33 GTR 8 months ago, I drove both V-Spec and non V-Spec and could not tell the difference, as the non GTR that I ended up buying had Tein Coilovers and there was no difference that i could tell. I presume you might notice a slight difference if you were using it as a track car. that is another reason why I chose the non V-Spec, as it was a little more unlikely to be used as a consistant track car in the past.
I have to say the VSPEC feels a bit stiffer and corners slightly better...besides that, it's just the internal trim and a few other items that are noticable. If it's a huge price difference, I wouldn't bother going Vspec.
I ended up with one as the price was so good for mine. Good luck.
Nothing in the interior is different btw the vspec and non-vspec....
this man speaks the truth.
Hey mate...I can only speak from my own vspec GTR...seat trip is better - has purple stitching along the sides and material is different from my mate's GTR. Also, side inserts are different...correct if I'm wrong but from what I've seen those are the differences.
it was just a general question as i had brought a midnight purple r33 gtr v-spec and i was told they had a better diff or something along those lines and a mate was saying there was no difference in them...
yes as posted above the vpsec has the active LSD diff in the rear
if you look underneath your diff will have fins on the cover, normal GTR doesn't have fins
instead of normal viscous LSD its computer controlled LSD
when the computer detects wheel spin (seperate to the AWD computer)
it locks the rear diff and the slip light on the dash will come on
is it better? maybe
mine sucks ass
The main place you will notice the difference is on the track. Last December at Winton I raced both my r33 GTR non Vspec, and also went in an R34 Vspec. The difference in cornering is quite noticable. On hard cornering, my car tends to lock up the inner rear tyre somewhat, but if you set it up right - slow in fast out - it still hauls ass and slingshots out of the corner. In the R34 Vspec it felt like the guy could throw the car into the corner any which way and as long as he kept his foot on the gas the car would just pull itself straight. The Vspec LSDs adjust touque split not only front to back, but also side to side. You can feel the car putting less torque to the inside rear tyre on hard cornering, pulling the car around at warp speed with what appears to be minimum driver effort. I wish I had bought the Vspec, but I still love driving mine.
if you plan on chasing power non-Vspec is the way to go... the diff is the strongest of the GTR diffs and can be easily upgraded for more aggressive lock as its mechanical/clutch pack type
The Vspec diff is viscous (fluid) like the GTSt diff and can't really be modified... and as Paul has stated they kinda suck ass;)
ah yeah thats right, i remember ben saying the vspec diff is a bastard to upgrade and its too small to shim inside it or very little room
mine is sometimes the greatest thing ever, other times its hopeless
the only distinct advantage i found with the vspec was it looks like it predicts wheelspin sometimes
i found on the great ocean rd on some of the sweepers if you gave it curry
the slip would come on even though it wasnt actually slipping, almost as if it was predicting wheelspin (from lateral force sensors)
kinda groovey
but otherwise hopeless
i should try and shim it and see what happens
yeah I think for a standard car, or lightly modded they work great... just if your planning to do power upgrades or get serious about track work its best to go for the non Vspec diff
one of the best mods I did for the old car was ditch the standard LSD... it was just unpredictable, made it hard to drive the car fast... but then again it was pretty shagged
must admit I've never driven GTR or GTSt with the active diff so I'm half talking out my arse;)
the seat colour trim is different between series 1,2 and 3
it's not related to vspec or non vspec
the colour purple is series 1 and 2
the colour red is series 3
You are correct paul.
As for my vspec diff, it seems to work great both on the road and on the track....too be honest if I'm cornering hard enough to loose grip in the R the last thing I'm looking at is the dash so I can't really say how often the slip light comes on. It seems the only time they suck is when they are being modified or they break.
  • 7 years later...
Hey fella's
Apologies on bringing up a pretty old thread. But I have purchased / rescued a 1995 s1 none v-spec gtr as it was the only original mnp and completely stock gtr within my reach.
And I am curious about the lower/stiffer suspension of the v-spec? Can anyone list the actual differences in the suspension components between an s1 vspec and s1 none vpec?
Thank you!
Congrats on the purchase - these things are only going up in value!
I believe it's a 10mm ride height difference and this should be in the springs themselves. No reason they can't be swapped between the two and any 33R suspension will fit it.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
    • re the security system, my Fuga/Q70 has the factory option where the puddle lights in the mirrors turn on when the prox key is detected, it was clearly dealer fitted and has a switch in the lower dash to disable it....it didn't have remote start but TBH I don't really miss that, I had it in the Stagea originally but never used it....we don't often have to warm the car up in the snow before we get in for Australia. And the Fuga also has the illuminated footwells, sounds like a useless feature but I actually quite like the indirect light within the car, it was a nice addition
