R32 GTST BLITS VENTED BONNET
ADR approved - In gel coat(white) - bit of TLC needed
$550 or swap 4 GTR bonnet and guards
Sam 0423 648 114
hey mate, any chance of a pic with it on ur car?
cheers
  • 3 weeks later...
