Hey guys I recently cracked my front bar :) devo as but also excited because it's shoping time :) just wanted to know if the r33 gtr s1 front bar can fit on my gtst, I saw some gtr lookalikes for gtst but I want to stay away from fibre glass for a while , would I need to change the guards and bonnet please let us know cheers guys
https://www.sau.com.au/forums/topic/303236-r33-gtr-front-bar-on-gtst/
i searched this as well but can't get definite answer!
this is a summary of replies
1. it won't fit
2. it will fit but wont be flush and the side mounting points have to be pushed in cause gtr guards are wider
3. it fouls the reo <---- true or false?
  • 3 weeks later...
If you want a GT-R front bar to fit your Series 1, but don't want to pay sh*t loads for a genuine item - take a look at Powerplayimports.com and check out there east bear bumpers, they make replica's of the GT-R kits for normal skylines that bolt straight on and they are plastic not that crappy fibreglass stuff.
can someone who actually got a genunie r33 gtr bumper on there gtst post how they fitted it?
like did you really need to cut into the reo to make the bar fit? i'm not too fussed about the guards not lining up and stuff since i don't use bolts to hold the bar on
mick from micolour told me that its definatel possible and that it can fit properly, but its not cheap :D
do you reckon 20mm front guards will help? mine are kinda rusting so considering getting wider fibreglass guards
im not too fussed that the gtr bar fits properly as long as it goes on without hacking into the reo
and i probably bend the bar at the sides and cable tie it to the guards!
cause i can't seem to find a series 2 front bar for cheap
    • See my post here If you put the Haltech in, you won't have to worry about any of that. And, in case you're worrying about my lack of credentials in doing your exact swap, I put a Neo in an R32. There has never been a stock boost solenoid near my car and the Neo's ECU has never cared. Nor should it, because it is electronically impossible for it to care.
    • That's 100% wrong. Did you wire in the boost sensor? If you did not, then that is 101% your answer. Neo ECUs do suck a bit.
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
