Hey guys I recently cracked my front bar :) devo as but also excited because it's shoping time :) just wanted to know if the r33 gtr s1 front bar can fit on my gtst, I saw some gtr lookalikes for gtst but I want to stay away from fibre glass for a while , would I need to change the guards and bonnet please let us know cheers guys
https://www.sau.com.au/forums/topic/303236-r33-gtr-front-bar-on-gtst/
i searched this as well but can't get definite answer!
this is a summary of replies
1. it won't fit
2. it will fit but wont be flush and the side mounting points have to be pushed in cause gtr guards are wider
3. it fouls the reo <---- true or false?
  • 3 weeks later...
If you want a GT-R front bar to fit your Series 1, but don't want to pay sh*t loads for a genuine item - take a look at Powerplayimports.com and check out there east bear bumpers, they make replica's of the GT-R kits for normal skylines that bolt straight on and they are plastic not that crappy fibreglass stuff.
can someone who actually got a genunie r33 gtr bumper on there gtst post how they fitted it?
like did you really need to cut into the reo to make the bar fit? i'm not too fussed about the guards not lining up and stuff since i don't use bolts to hold the bar on
  joeyjoejoejuniorshabadoo said:
mick from micolour told me that its definatel possible and that it can fit properly, but its not cheap :D
do you reckon 20mm front guards will help? mine are kinda rusting so considering getting wider fibreglass guards
im not too fussed that the gtr bar fits properly as long as it goes on without hacking into the reo
and i probably bend the bar at the sides and cable tie it to the guards!
cause i can't seem to find a series 2 front bar for cheap
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
