Need a little help here. Spun bearings on my RB26 motor and now gathering parts for the rebuild. Problem is this............my builder looked at the block and noticed there was crank walk with some damage on the edges of the block where the main bearings would sit. the thing is when we put the new main bearings in the block, the damaged edges do not affect the area where the new main bearings will sit, my question is this............should I discard the block or can it still work? I've tried taking some pictures to show the damage. Thanks guys.
Picture taken from rear of the block.
#6
#5
Center
#3
#2
#1
I hope these pictures help, thanks again guys.
https://www.sau.com.au/forums/topic/303238-is-this-block-still-good/
My guy was saying he did not want to line bore because he was afraid that it would probably cause the oil pump not to line up properly (not sure if I am quoting him well). Thanks much for your reply though, it means a lot to get help on this forum.
i would line bore it to make sure it is still true.
Ditto.
If you just buzz the burr off the edge and run a tunnel hone through it you shouldn't have any issues with pump alignment or tunnel size. The tunnels do pinch up across the parting face when they get heat into them. Doing a thrust bearing like that can cause a fair bit of heat so it's worth checking out.
Ye i guess, it is putting pressure on the crank but i takes one hell of a pressure plate to be the single reason there's crankwalk, im guessing the engine has taken a beating and all combined with bad bearings the pressure plate has helped to cause this but not a pressure plate alone :rolleyes:
    • Haha actually I did join back then under a different email address,  I couldn't re-activate my account so made a new one! I didn't post much anyway so not missing out on much. Amazing to see how the value of the cars and parts has changed over the years, also ACT section appears to be dead now.
    • Thanks... It's in pretty good condition overall, probably due to not being drifted/tuned however being a daily driver has taken its toll. Had 100k on the clock when I got it, up to 180k now. Unfortunately it's not 100% dent free, it's got a small dent on FLH side and broken indicator from where I hit a small kangaroo at high speed. If you look at closely at pic #5 you might spot the dodgy trailer light repair my old man and I rigged up as temporary repair! - It's still there due to a combo of needing the car as daily driver and then too lazy/busy to fix properly. I've a couple of other minor accidents accidents as well but nothing major. One required a new front bar and unfortunately the smash repairer ordered the normal gtst one and not the aero bar. Needed the car back asap so just went with it, regretted ever since.
    • I can't believe that anyone is foolish enough to believe that the base maps are for any other purpose than to drive the car up onto the trailer/truck or gently creep it to the dyno. No matter how good they are, they can never be any better than the factory maps**, and only the foolish trust those on a significantly modified setup. **Yeah, yeah. I know there's also the difference between factory maps being fixed to certain injector sizes and MAP/AFM/VE relationships, and the likely aftermarket ECU base maps being better able to handle the sorts of changes that would render a stock ECU dangerous, like different sized injectors. But let's just ignore that for the moment, because the principle is still the same.
    • I'm shocked, you've owned a Skyline since 2006 and never joined SAU before now! 😮   Welcome, it's much quieter these days than it was in 2006, but lots of very knowledgeable ones lurk around here. I actually think in outage we've forgotten more about Skylines than anyone knows about them today... 😛
    • So it could give us some info. Such as we find out what number they started at, and we know how many of those blocks came before it.
