  • Replies 154
Its a awesome game, im a big fan of Final Fantasy series, but i found 13 to be too passive, all you do is go from A to B, but apart from that its got a good storyline which makes the game.
but still FF10 holds its number 1 position in my books =)
FF8 was the most epic out of all of them. Wicked storyline, awesome game-play, unparalleled diversity. I remember i clocked up a good 90+ hours on that game through high school.
Hell, i started playing it again not long ago. Bought it off the PS Store for like $12.
On another note, i just rocked upto the Orphan Cradle in FF13. Almost finished the main storyline.
yeh they have been goin downhill fav was 10 :)
Agreed, final fantasy is all bells and whistles now. The best ff games are the snes ones, 3,4,5,6 have the best stories. 8 was amazing. Then they slowly became a little dated. FF13 looks good but then again x-2 looked good LOL and it was horrible.
Play cronotrigger and crono-cross (awsome)
different summons,
ff9 had a bizzare summon system. Different stories, all based around the crystal though..lol some things never change.
Its a shame the FF8 summons did not all see there way through to FF10-13, pandamonia, siren, doomtrain, brothers and diablo are the best!!!
there are other RPG series that play alot better than the FF series though with far more engrosing stories.
Edited by oh-so-swift
Ok so it arrived yesterday and I got in about 4 hours or so...
It seemed rather linear the whole time however it moved you to where you needed to go for all the cinematic experience and to familiarise you with the world, the fighting and mobs on the path etc.
At hour 3-4 I became a l'Cie... suddenly combat got fun then by the 4th hour they added Paradigms. I dunno what people are whinging about I am quite happy with the eye candy and baby steps into the world. You can tell they are slowly increasing difficulty as they push you into the story...
I just got a ps3 and got this game, havnt played it yet it looks amazing. Cannot wait. Funny enough i heard that when ur lvlin up your characters if you see two different types of creatures they battle each other everywhere which is funny as. Cause you can be close enough, enjoy the fight, then kill the weakened creature and collect the drops/exp.
MSTRshenanigans
I'm enjoying being able to see and run from encounters where needed!
That's always a plus. Wonder how well they have done the gameplay with the summons.... Cannot wait to play it 2nite and find out.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
