I drive a 2000 model Nissan Stagea RS-Four S. I had a 'Nistune' board installed at Springy Motors in Victoria just before we moved to Orange in central west NSW.
As far as I can tell according to their website, the nearest Nistune garage I could take my car is in western Sydney. Does anyone know of any garages within 200kays of Orange (ie Bathurst, Lithgow, Dubbo etc) that I could take my car to get the Nistune tuned/programmed?
Additionally....has anyone found that their fuel consumption is any better with the Nistune chip? I thought the economy might improve with the new ECU, but still only seem to be managing around 420-450 kms to a tank of fuel. (I would like to get the chip re-programmed for maximum economy rather than maximum power next time :) )
Cheers,
Tom
I would make the trip to Sydney to one of the reputable tuners.
BTW I have family up there in Orange and Bathurst and will be purchasing some property in Orange in the next few weeks.
Thanks Wolverine,
Sounds like I may have to bite the bullet and make the trip up to Sydney one weekend. The two western-most garages in Sydney that are listed on Nistune's website are;
Unique Auto Sports
1/20 Tucks Road, Seven Hills, NSW
Contact Tim on (02) 9620 9000
info [at] uniqueautosports.com
http://www.uniqueautosports.com
Unigroup Engineering
17/ 17a Amax Avenue, Girraween
(02) 9631 2470
Contact Yavuz on (02) 9631 2470
enquiries [at] unigroup.com.au
http://www.unigroup.com.au
I wonder if either of these Nistune workshops would be open Saturday morning (the only time I could really book the car in). Has anyone had any dealings with either of these garages and can recommend?
Best of luck with the pending real estate purchase Wolverine!
Additionally....has anyone found that their fuel consumption is any better with the Nistune chip? I thought the economy might improve with the new ECU, but still only seem to be managing around 420-450 kms to a tank of fuel. (I would like to get the chip re-programmed for maximum economy rather than maximum power next time :thumbsup: )
Cheers,
Tom
Whats your problem? I can't get 400 out of my tankfull!!
  • 1 month later...
An update -
Have recieved two quotes back for the major service - both around $1680. This includes;
Replace engine oil and filter
Replace timing belt
Undercar inspection of suspension components, tyres, brakes, and chassis.
Remove/refit drive shaft for dyno operation, 4wd vehicle.
Dyno test/tune - check state of tune (fuel and ignition), power and general running. optimisation of boost pressure, ignition timing and fuel mixtures (where applicable) on dyno and before and after power printout.
Replace water pump
Remove radiator and flush cooling system, replace coolant
Replace gearbox fluid
Replace differential fluid
Replace transfer case fluid
Replace clutch fluid and bleed clutch system
Replace brake fluid and bleed brake system
Check condition of air cleaner and service/replace as required
Check condition of auxially belts and adjust, tension and replace as required
Check condition of radiator hoses and replace as required
Check condition of vacuum hoses and replace as required
Intake system leak/smoke test.
Replace spark plugs
Does this sound reasonable? Has anyone purchased the Kudos motorsports 100,000km service kit and installed themselves? I'm guessing replacing the timing belt etc would be a bit beyond the skill of an average bloke? Grrr, so much money. Any thoughts or suggestions appreciated.
There are instructions for doing most of those things either in the DIY in the sticky at the top of this section or in the general skyline DIY section. In our Stagea DIY section under "fitting an adjustable cam gear" SK gives instructions on how to chnage the cam belt (and also suggests that the water pump is good for 200,000km and should n't (or needn't ) be replaced unless it is faulty.
If you have the time and inclination you could do all of the above (perhaps not on the same day) over a few weekends. Replacing the spark plugs e.g. is a two hour job the first time but much easier the second (there is a tutorial in the skyline section).
Save your money for the tune!
my un tuned rs fours s gets 430 kays from full to fuel light TOWING THE BOAT non stop at high way speeds .
not towing the boat and not much load in car and the boost controller turned off i got 1200 kays out of 130 litres two tanks + $40 which isnt much at $1.86
Edited by lachlanw
Cheers,
Tom
just having the nistune daughterboard won't make any difference to the car at all mate. you need to get it tuned before you start improving fuel economy :devil:
  • 3 weeks later...
Hi Question can you run a boost controller on the standard ECU with no mods and if so what boost can you run ?
Phill
Phill
You could probably run 10 psi ok but you'd be better to spend the money on a 3in turbo back exhaust as your 1st mod. You could get 10psi for free by bypassing the solenoid or just the better exhaust will give you more flow anyway.
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
