Do anybody's S2 + and - lights illuminate at night? I replaced the two globes on the driver's side of the gearstick and now my gear indicators sort-of light up, but the + and - buttons stay dark... which seems wrong.
With the lights, only two globes on the drivers side with a diffuser that goes around
all the gear selections including the + & -, however even with two new bulbs in
the + & - still dont light up.
Need brighter bulbs or retro fit a bulb/led on the left somewhere and they should light up fine.
2x 5w bulbs as said by 666DAN :banana:
  • 1 year later...
Okay, so I pulled the shifter apart today and found out it is actually relatively simple to get to the two bulbs underneath. First you need to take out the surrounding part of the console by removing the screw behind the ashtray and then prying it up with a blunt, flat object. Next you will need to use a philips head screwdriver to remove the two screws holding in the shifter itself. After this it is just a simple matter of prying off the plastic that surrounds the remains of the shifter (small white stick looking thing). Once this is done there are two small (tiny) globes directly below the "PRND32" section that can be removed/replaced. I will upload pictures tomorrow once I have the replacement bulbs!
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
