Item: External 38mm 2-Bolt Adjustable Westgate + 7PSI Spring Set
Features:
- Compact 38mm piston
- Fits in the tightest of engine bays!
- Adjustable 7PSI spring set (2 springs included)
- Spring tension adjustable via the top nut (like a BOV)
- Dual ports w/ 2 NPT fittings (top & side)
- Electroplated high-temp 304 Stainless Steel base
- Treated 6061-T6 aluminium actuator housing
- Diaphragm reinforced for maximum valve travel
- CAD designed bowl insures air flow efficiency
- Inlet/outlet 2-bolt flanges + gaskets (polished)
INCLUDES ~ All necessary installation accessories + 2 springs
$185 including Delivery & Insurance
Contact: 0401599023 (anytime) OR [email protected]
-- ALSO AVAILABLE in 50mm & 60mm - 24 PSI variants --
  • 1 month later...
