Hi guys,
I've just put in an r32 rb20det into my r31 - it's all wired up, engine is cranking but wont start!!! Does anybody know what this could be?? I've checked the computer wired it - re-wired it! still the same problem! Is there something I could I could've done wrong in the wiring?? Anyone here had this problem before??
I'd really appreciate some help!!
Thanks
First things first:
Is it getting fuel? Fuel pump working during cranking?
Are the injectors operating?
Is it getting spark?
Factory or Aftermarket ECU?
Factory ECU - it's definitely getting fuel and the fuel pump is working during cranking..
is there a way to test the injectors??
Got a wiring diagram for the 32 eccs model in a r31.. if you get stuck can send a copy ..cost me big $$$ when i had my 31 wired when it came back from sparky we went right through it and copied it .. :D
Could you please send me a copy!! I'm desperate for help
[email protected]
The factory computer wont fire unless it's got all the inputs from the MAF and Crankangle sensors working, I'd check that.
Also check that the computer is getting power while the key is in the cranking position, not just the ignition position.
Also check for spark. Romove a coilpack and put in a spare plug and see if it sparks when you crank.
ECCS Pinouts:
AFM -> ECU:
1 blank
2 -> 27 Signal
3 -> 60 (Ground)
4 -> 26 Ground
5 -> 49 (+12V)
CAS -> ECU:
1 -> 41, 51 - 120 deg signal
2 -> 42, 52 - 1 deg signal
3 -> 49, 59 (+12V)
4 -> 60 (Ground)
Check that you have the fuse/fusible link wiring all correct. I blew the fusible link running off the positive terminal of the battery on my 31, itd crank but not start. Removing certain fusible links in the bay also did the trick.
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
