He I was wondering if anyone here has experience with the Apexi boost control solenoid for the power fc.
I broke a power fc a while ago and have sence soild it and I still have the boost controler stuff so I just want to find out if every thing is there and then it will be up for sale
https://www.sau.com.au/forums/topic/303336-apexi-boost-controlar/
What pfc model was the boost controller for?
dunno man, ill give ya $100 for it :-P
$120 and you can have it. Its only sits only sitting in a box in my bed room same place it has been for a year doing nothing so. and that should be enough to cover the rest to get my 3 1/2 inch dump pipe made up for the 31
Edited by lawler
The boost controller kits arn't all the same. You can actually fry a FC board if you plug in the wrong model boost controll kit to the wrong board.
I'll take it for 120 delivered to Lutana/Moonah Tas.
Cheers
J
Edited by XRATED
" The optional boost controller kit for the Power FC consists of the pressor sensor, pressure sensor harness and solenoid. The solenoid should be plumbed between your manifold and the wastegate actuator (internal wastegate setup). For external wastegate setup it should be plumbed between the manifold and your external wastegate pressure line. The pressure sensor should be plumbed in parrallel with the factory MAP sensor which is used by your standar boost guage.
The solenoid has two labels on it, you should match them accordingly
COM line should goto wastegate actuator
NO line should goto intercooler piping
It can be T'eed into the plumbing with its included T piece fitting.
Boost Controller Kit Type #1
3 wire plug, Solenoid runs to stock boost control loom on stock ECU wiring loom.
3 wires in Apexi loom are for Map sensor - Signal, Ground and Power
Boost Controller Kit Type #2
5 wire plug, Solenoid runs to map sensor harness which runs to Boost Controller port on PowerFC
3 wires are for Map sensor - Signal, Ground and Power. 2 Wires are for Solenoid Power and Ground
Skyline RB25DET PowerFC and GTR RB26 Uses Type #1
The pressure sensor has the main wiring harness directly attached to itself, one end plugs into the 5 pin port on the PowerFC. The solenoid piggybacks off the Pressure Sensor wiring harness which leads to the PowerFC connector port. The wiring is shown below. ""
Its to suit an rb25det so ill say its a type 1. Ive gota go to work now so ill double check tommorrow.
And yes I know its cheap and now theres 3 peoplesay they want it. Could all ways pm me anoffer and see which way it gose?
f**k me red your spelling is shit house
so red how did you f**k your computer ? didn't wire it up wrong did you ?? lol
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
    • OK, so the weight has been bugging because it was really low. I did it again today and got a more believable answer at 1246 without driver And with a 93kg driver I'm pretty sure the car was still slightly on the quickjack last time meaning the full weight was not on the scales
