iseekool Posted January 11, 2010 Share Posted January 11, 2010 Hi all, Just wondering what is the normal coolant temps for hot days. The reading are based on the CONSULT box. Lately I've been in the 88 to 93 degree range, sometimes hitting 97 if the a/c is running - Usual is around 84 to 86 degress. On the last 38 degree day my coolant temp reached 103 degrees - with my a/c on in traffic. Just wondering how my car will go on this 43 degree day with the a/c running... My car is pretty much stock. Link to comment https://www.sau.com.au/forums/topic/303350-teh-heat/ Share on other sites More sharing options...
(OO)SKYLINE(OO) Posted January 11, 2010 Share Posted January 11, 2010 would not worry about it too much, it's normal for temps to go higher on hot days. Just make sure your radiator coolant is topped up and check regularly. Link to comment https://www.sau.com.au/forums/topic/303350-teh-heat/#findComment-5027419 Share on other sites More sharing options...
180Roman Posted January 11, 2010 Share Posted January 11, 2010 when the weather is in the 30ies my temps hover around 94-96 with air con going Link to comment https://www.sau.com.au/forums/topic/303350-teh-heat/#findComment-5027541 Share on other sites More sharing options...
Travis Trayhern Posted January 11, 2010 Share Posted January 11, 2010 any turbo car suks balls in this heat just park it and drive another car thats na lol Link to comment https://www.sau.com.au/forums/topic/303350-teh-heat/#findComment-5027629 Share on other sites More sharing options...
macdog Posted January 11, 2010 Share Posted January 11, 2010 any turbo car suks balls in this heat just park it and drive another car thats na lol Good call on that one, need ice cold temps! Link to comment https://www.sau.com.au/forums/topic/303350-teh-heat/#findComment-5027797 Share on other sites More sharing options...
astrotristan Posted January 11, 2010 Share Posted January 11, 2010 my temps are around 72degrees (without aircon) Link to comment https://www.sau.com.au/forums/topic/303350-teh-heat/#findComment-5027803 Share on other sites More sharing options...
joeyjoejoejuniorshabadoo Posted January 11, 2010 Share Posted January 11, 2010 i dont get it.... my car is fine in the heat.... Link to comment https://www.sau.com.au/forums/topic/303350-teh-heat/#findComment-5028295 Share on other sites More sharing options...
Rekin Posted January 11, 2010 Share Posted January 11, 2010 my temps are around 72degrees (without aircon) 72 degrees is quite cold. Isnt the efficient operating temperature around the 80 degrees? My car cycles from 82 to 95degrees depending on weather. Link to comment https://www.sau.com.au/forums/topic/303350-teh-heat/#findComment-5028538 Share on other sites More sharing options...
eMsta Posted January 11, 2010 Share Posted January 11, 2010 mine went up to about 101 today - with a/c on. stayed constant on that..... Link to comment https://www.sau.com.au/forums/topic/303350-teh-heat/#findComment-5028543 Share on other sites More sharing options...
krzysztof Posted January 11, 2010 Share Posted January 11, 2010 generally 80-82. today for example 43degree heat a/c on sitting in traffic it'll see 86 if its lucky, once we get moving again back down to 82. i have an alluminium radiator though.. Link to comment https://www.sau.com.au/forums/topic/303350-teh-heat/#findComment-5028928 Share on other sites More sharing options...
htial Posted January 11, 2010 Share Posted January 11, 2010 I'm showing my dumb cards... What's a CONSULT box???... Link to comment https://www.sau.com.au/forums/topic/303350-teh-heat/#findComment-5028962 Share on other sites More sharing options...
iseekool Posted January 11, 2010 Author Share Posted January 11, 2010 I'm showing my dumb cards...What's a CONSULT box???... http://www.ecutalk.com/ I got it from these forums about a year ago, from a guy called "newkleer" (cannot remember the spelling) Link to comment https://www.sau.com.au/forums/topic/303350-teh-heat/#findComment-5029437 Share on other sites More sharing options...
astrotristan Posted January 12, 2010 Share Posted January 12, 2010 72 degrees is quite cold. Isnt the efficient operating temperature around the 80 degrees?My car cycles from 82 to 95degrees depending on weather. my thermos run off the thermostat which is 68ish degrees, so far have seen a max of 80 had a max of 95 - but that was because the fuse blew in the 14" thermo lol once the engine has been run in and im actually pushing her it will be interesting to see how she holds up Link to comment https://www.sau.com.au/forums/topic/303350-teh-heat/#findComment-5029478 Share on other sites More sharing options...
geraus Posted January 12, 2010 Share Posted January 12, 2010 hmm mine was at 80,81,82 driving to Lorne on a 42 degree day, with the ac on to... Link to comment https://www.sau.com.au/forums/topic/303350-teh-heat/#findComment-5030080 Share on other sites More sharing options...
bonestorm007 Posted January 12, 2010 Share Posted January 12, 2010 Anything over 95 is no good. Best to get your radiator and cooling system checked and flushed out. Link to comment https://www.sau.com.au/forums/topic/303350-teh-heat/#findComment-5030796 Share on other sites More sharing options...
