Yes it is fine.
The way I normally do it is to buy Redline shockproof and a 1oz bottle of friction modifier.
Put the redline in and drive around the car park. If the diff is grabby, then put in 1/4 of the 1oz bottle. Test it again and keep adding until it drives smootly or how you want it.
75 vs 80 is not really anything to worry about.
https://www.sau.com.au/forums/topic/303362-mech-diff/#findComment-5027471
Heard of some bad experiences with shockproof in mech diffs so i'll be using the 75W140 and the Redline friction modifier as well as i hate a overly noisy diff
The bad experiences you heard of are most likely to be from people who have used it without the friction modifier. It seriously makes a huge difference. But as with anything, there is always a compromise. Redline is IMO the best quality gear fluid available. Some people don't like it, others love it. I have never had a single problem when using it and have only ever had good reports back from customers.
https://www.sau.com.au/forums/topic/303362-mech-diff/#findComment-5027591
