More sleep, less alco will fix the eyes :banana:
How did you fail last time? What grade sandpaper did you use? What did you do after you sanded to finish the job?
Ive never sanded mine. Just used an old T shirt/ singlet and get good results out of whatever brand polish I have in the shed at the time. Goes from a lightish color with yellow tinge. When finished the headlights look much darker. Only takes 2-3 minutes per side. Repeat roughly every couple of months. I did try meguiars metal polish once but found that just a general general brand polish did just as gooda job.
Edited by l_uk3y
I bought a kit off eBay - little bit of sanding involved but they give you the correct sandpaper. Think it was called glassylite or something like that. Cost me about $30. Headlights look pretty good now.
I stopped at a Bursons store yesterday and noticed they had the same sort of thing for about $50
Likewise. Glassylite kit is the best stuff...comes with sandpaper, cleaner, polish and nano-sealant. Mine are still clear as daylight and it's been about 2 months since I used the Glasslite.
20 months on and mine are clear as. Why not use a SAU Vic supporter in Final Inspection? Get the car detailed, headlights done at the same time and you're good to go.
I still recommend to people, paint polish and a MACHINE, not a 'hand job' will give you the results you really want. Some headlights do require a wetsand if really bad, but most times, you can just attack with paint polish and a machine. Keep them waxed and you shouldn't have an issue for a long time IF corrected properly in the first place.
If the FI gallery wasn't down, i'd show you what can be done with paint polish and a machine ... Damian took some great shots...
SS8, whats a machine..? im not following when you say polish and a machine...
anyway im gonna try again to scub them out a bit this afternoon when it cools down, cause SHIT its hot today... not as bad as yesterday but still >.<!
i might just try toothpaste first ^_^
he means polish it using a machine
i did the lights on my R34. only did a half assed job cause i was just seeing how it comes out and it came out good.
got myself some mild rubbing compount and gave the geadlights a good rub. the grains int he cutting compount cut away 90% of the yellow tinge but after a quick wipe it left the headlight dull. then got some paint polish and rubbed it on the headlight. using a buffer (machine) i buffed the headligth then put a coat or carnuba (sp) wax on it. and its come out awesome. all up each headlight took me 20mins
depending on where your located i can come and do yours for you.
wahhhh
if ur Serious about it ashneel ill take u up on that, im in wheelers hill like 10min away max..
anyway pm'd u
kitten plastic polish and a terry towel. takes a few applications and will fix them right up. Take you 5 minutes. May have to do it every couple of months or so depending. Dont bother with the whole sandpaper bullshit, whole lot of work for no reason
use AUTOSOL metal polish from supercheap auto , any other plastic polish is ok but this kicks ass
pretty sure theres a reason its metal polish and plastic polish
just taking a guess and saying different chemicals in each and could damage if used on wrong application
    • They usually get made by hand as part of any such swap.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
    • Does anyone know if this is off centered? Looks like it, when I indicate to go right, but turn my steering wheel slightly left it cancels (was always like that even before I started messing around with it) was wondering if anyone else has the same issue?
