R32 Rear Seat Removal ...
hr32gts
 Share
How the heck do ya remove the backseat in the R32 skyline ... Gotta take it out so that I can shampoo and deodorise it all properly
My dog after puppy preschool Tonight decided that he would do a number 3 all over my backseat ...
POO EXPLOSION ...
Not happy jan
Nearly vomited on the way back home Disgusting
Figured it out ...
Pull the back part of the bottom peice out first then pop the clips out ... which ya have to reef and pull on hard cos they are tiiight ...
then the top peice is just 2x 10mm bolts and then lift the seat upwards then pull back towards yourself ...
Easy ...
Also found shitloads of broken glass , a lighter , 10 cents and a mobile phone under the rear seat fun fun
Now the big cleanup begins ...
Figured it out ...
Easy ...
if you do this ull end up bending the clips at the front.. and good luck geting them bak in when ur refitting... ur bottom part of the bak seat must come out 1st... simply stick ur hand under find where the bottom clips are sitting stick in a breaker bar far in and reeeef it up ull hear a snap sound dont worry coz its just the rusty clip coming out nothing will break... do the same to the other side... these are just U shape stick ins their not curved in or anything... once the bottom is out ull see the back seat top part is bolted in at the bottom think it was a 8mm nut on both sides..... once their out push up and pull back the seat will come off... !!!:) let me know how u go!
Regards George
Put my seat back into the car today ... still stinks but hopefully will disapate with some car cologne stuff ...
Also I put the bottom back in first ... and then squeezed my hand in between the seat to do put the 10mm bolts back in ... pretty easy
Edited by hr32gts
  • 4 years later...
Best thing to do is remove seats, then soak with CT18 Truckwash, the pressure wash it until it runs clear, hang the seats up in the garage on an angle (so it drains to a corner)for 2 days.
Just did that to 100,000km of Nissan Patrol outback dust, they look new.
Yes i know its an old post but this might help the next person that searches.
Edited by xfixiate
 Share
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
    • Here's the torque curves from the car I ramped boost up later in the rpm to allow a slightly wider useful power curve - the power curve is a bit weird shaped also thanks to the TVIS (or whatever they call it with the 4EFTE in this Starlet) which changes the volume of the intake manifold throughout the rpm range, but you can see that the green power curve actually holds later on with the extra boost... but looks almost more like the kind of thing you'd expect from a cam or exhaust change
