Hi,
Looking into doing water-methanol injection system and just want to double check I wont be causing any damage.
Just want to clarify the hoses located in the blue circle labeled 1 to 5 (disregard the red, using picture in another thread)
Hose 1: Draws air from manifold?
Hose 2: ?
Hose 3: Manifold pressure hose for fuel rail (does this blow manifold air through or is it a vacuum?)
Hose 4: Coolant?
Hose 5: ?
Do any of these hoses flow air from the intake manifold? As the air will be mixed with water/methanol I want to know if this air goes straight to the engine or do they bypass through any of those hoses?
Thanks :D
https://www.sau.com.au/forums/topic/303467-what-are-these-hoses-rb20/
1 is the pcv, flows towards the manifold under vacuum and doesnt flow at all under boost (pcv valve closes)
pretty sure 2 is coolant, not air
3 is vac line for fuel reg as u said, doesnt flow just pressures/vacuums. however i dont think methanol would be too good for it.
pretty sure 4 and 5 are coolant
1. PCV vacuum
2. Coolant to throttle body
3. Fuel Pressure Regulator vacuum
4. Coolant from plenum to coolant galley above injectors
5. Coolant feed to plenum
Sweet thanks for that guys. Hose #1 and #3 are explained as vacuums. Although would any manifold air pass through these pipes?
As I will be hooking up a catchcan to the piping, would I end up with a puddle of water/meth? What about the fuel pressure regulator?
Tap the methanol into the cross-over pipe that fits directly to the TB. Any other means of supplying methanol to the A/F mixture isn't going to work.
The "J" pipe about 4" before the throttle body is the best place although someone did mention that the water gets back into the compressor when the bov operates and may cause some erosion of the wheel over time
yeah the plan was to mount the nozzle on the cross over pipe but as mentioned by smell, this water/meth will then be recirculated through the turbo and intercooler due to the factory bov. I have found some nasty pictures of pre-turbo water/meth sprays which have chewed through the fins.
I was thinking of mounting the nozzle after the TB, that way nothing will flow through the turbo. However, im not sure if I would get an even spray to each cylinder as the manifold is quite large..
So yeah, any chance of methanol causing damage to the PCV and fpr?
Thanks
#1 won't supply the mixture when you are on boost - and that is when you want the mixture most.
And #3 is simply a pressure source for the FPR - no air actually flows through the hose.
If you feed directly into the manifold, after the TB, you risk uneven distribution of the mixture to the cylinders.
Tap it into the cross-over "J" pipe. Any methanol flowing back through the BOV will probably drop out because it will be a low velocity air flow.
Thanks for that. Feel more comfortable going ahead with the water/meth.
Just need to find a solution for any water/methanol flowing back to the turbo. Perhaps a type of filter/catchcan to remove any water/methanol from the air, or reroute the bov piping so it feeds the air after the turbo instead of before..
cheers
cheers
You can't feed it back to "after turbo", because that area is at the same pressure as at the BOV. It has to go back to "before turbo" ie low pressure area.
A lot of installations actually inject before the turbo because you can do it with a low pressure pump. If there was a risk to the impeller blades, I doubt they would consider it.
So what mods do you have?
Looks pretty stock to me
WMI needs a tunable ECU, and mods to make it worthwhile.
thats the idea, to look as standard as possible :D
Ive got nistune ecu, hks2530 and all the bells and whistles to support it.
Main reason i want the water/meth is for cooling as im getting detonation in heat, and the methanol is an added bonus :P
Ah bummer scratch that idea then.
Here are some pictures floating around of pre-turbo injections. A lot of suppliers also do not recommend it as they dont want to be liable for any damage. The benefits of doing pre-turbo sways people to try it out as it significantly cools the air before it enters the turbo.
But as you can see from the pictures, if the nozzles doesnt atomize properly, water droplets can do some damage.
This amount of damage was caused by a poor setup whereby the nozzle was dribbling water onto the fins.
Ok lets clear some things up.
I've been running a high pressure system for YEARS. The nozzle is plumbed in about 5 cm after the BOV.
There is absolutely nothing to worry about, it does not go back through, because if you buy a proper system, when you back off, the BOV will open, and the WMI system will stop pumping.
The only reason you'd put a before turbo system on is if you want to run the turbo above its standard efficiency range. This effectively movesd the entire compressor map top the right. BUT you will get decreased turbo life if you do not use a proper kit that atomises the mixture properly, and shuts off properly. There are systems out there that work like a fuel injector.
Anyway, do what I did, and there will be not problems. How to I know? I currently have my engine out of the car. The pistons are perfect. The turbo impeller is perfect. The inlet tracts are clean as a whistle. There is no carbon buildup.
As you can see, I used that lug to have more meat to tap into.
awesome thanks very much for the photos and your experience! Good to see other skyline owners having gone down the water/meth path!
Seeing as water/meth wont go into any of the hoses and cause no issues to the turbo I will now pick up the water/meth injection kit :D
Thanks all
Or if u want to be absolutely sure that u wont have any comp wheel damage u can install a nice shiny atmo bov and use the ecu to tune out the over fueling..... i know this can be done with the pfc , not sure about nistune though
I'm sorry but this is bad advice.
The BOV will not drag any WMI vapor through because when the BOV is open, the Intake manifold is under vacuum, and the WMI kit will not be pumping.
If you don't believe me, I can take a photo of my turbo right now and show you that it is in perfect condition.
I understand that part but when you're at wot and water is being injected and u snap the throttle closed u remain with some mist between where the nozzle is and the tb.... i know its not much but this little bit still gets sent back to the comp
In another scenario say you set the injection to start at 5psi and you're running 20psi at wot and u ease off the throttle but not totally, u might still be above 5psi so the injection keeps going but ur bov did open a little to get rid of the extra pressure so there will be some sent back to the comp as well
But hell....you've tried it and had no probs thus far and my wmi kit is still in my closet :thumbsup:
  • 3 weeks later...
alrighty
I agree more with
that's the doo doo doo/chopping sound that everyone loves...depends on the stiffness/adjustment of your bov spring but it often happens for a split second before the bov opens (or when the thing above that 'smell' said happens), and that's when there is potential for water/methanoled air hitting the compressor blades...and backwards too, omg......BUUUT (as stated in the pics above of the comp. blade damage) it only causes damage if there is un-atomized water meth droplets......plus think about the fact that only that tiny portion of air between the meth nozzle and throttle plate has been sprayed, so for it to even get to the compressor wheel it has to go through all the piping and the cooler, and be in droplet form. I imagine it would get caught in the cooler then evaporate pretty much instantly the next time you come on boost. If there was even enough actual liquid to form a droplet.
Maaybe if you pumped the throttle (full boost, full vacuum, etc etc) many times in quick succession that tiny bit of meth could build up and form enough for a droplet....but I reckon the hot air coming directly from the turbo would evaporate it anyway.
So assuming that's all correct, as long as you have a good high pressure kit (at least 150psi) that atomizes properly and dont spray too much (you will loose power anyway if you do) you wont have any compressor wheel problems.
Ive got a 32 GTS4 with 2530 too and am halfway through installing a snow performance kit at the moment, so im not talking from experience yet but I have read a whole crapload of info and talked to everyone I can think of, so am pretty confident with what ive learned. So if anyone knows better please let me know as I will be using the same 5cm from the bov setup as 'The Mafia' described.
Hope that helps!
Dave
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
