  • Replies 124
Hi, just to confirm these plenums are a direct bolt on and everything is included in the kit?
That's correct - a complete bolt-on including an adapter for your OEM throttle body!
  • 1 month later...
To start of 2011 - FREE P&H!
Check out the feedback; it's the real deal no problem RB25 plenum!
I've heard of alot of these manifolds leaking or needing to be pressure tested, or otherwise modified to fit perfectly before install. Do I need to check it out and test it thoroughly, or would it be right to install straight up?
Yeah there are a lot of poorly manufactured plenums out there - but after successfully selling these for over 4 years now we can proudly say these are not one of them.
It is cast alluminium so professional installation is recommended.
- Brendan
Sorry to be a pain, i've just been reading up alot on the greddy-copy plenums. So most seem to be okay if you shave/machine the surface where the gasket goes to make sure it's fully flat. Has that already been done to these, or are you sure it's perfectly flat?
I'm sorry if that's just a re-wording of the last question i asked, i just really want to make sure i get this done right first time, without having to remove it after fitting to get it machined or whatever :)
Hi mate,
Happy to help - this plenum was not machined or modified in any way just a good gasket was used.
- Brendan
So should I order a factory nissan gasket or something else?
This customer used his original one from what I have been told so it really depends on the condition of the one you have now.
- Brendan
  • 3 weeks later...
Hi,
I bought a set of injectors with an after marked fule rail, and its just to big to fit under the standard plenum and the injectores are now top feed instead of side feed,
they fit into a standard ser2 1996 skyline besides the clearance from the standard plenum.. so i would assume they would fit fine into ur plenum..?
so u can fit the standard throttle body up to ur plenum..? and were dose the idol solonoid from the back of the standard plenem mout on urs..??
and last but not least do u sell these in a raw finish or black..??
Thanx for you help..
Hi,
Hi,
In terms of the injectors you would need to test them yourself to check for fitment - our plenum does accept our own top feed style fuel rail so it should accept yours as well.
Yes - standard throttle body can be used with the adaptor included,
There is a host of connection points on the rear of the plenum to accommodated for all the correct wiring ect.
We do stock them in a plain cast aluminium finish.
We can also offer installation instructions if required.
Cheers,
Brendan
  • 2 months later...
  • 1 month later...
Hi mate,
The fuel rail takes 10.5-11mm top feed injectors (ie. GTR) rather then your OEM side feed injectors - they basically flow more fuel.
Of course the CNC machined purple rail also look great once installed.
- Brendan
  • 1 month later...
  • 3 months later...
Hi been looking around at a few of these.
i have a rb25 in my r32 would i have to change anything at all like the throttle cable?
and what is your price at the moment with postage to NT 0810
Please reply via pm thanks
  • 3 weeks later...
