  • 3 weeks later...
  • Replies 124
hey mate would sard side feed injectors fit straight into this setup? pretty sure they are 800cc if that makes a difference.
Hey,
It's intended to be used with your original fuel rail set-up.
- Brendan
  • 3 weeks later...
Hey mate, pretty keen. Got on that web link and couldn't find the plenums on there anywhere? anyway can i get pictures of plain cast and polished finish, and do these kits come with fuel rails also or are they extra? Cheers
Hey,
What link are you referring to?
I'll PM you a picture off the cast and chrome versions, this is just for the plenum but if you require the fuel rail as well it would only be $95.
- Brendan
hey mate could you PM me the price for polished plenum, 80mm TB and postage to 7015 thanks :)
Beau you have been PM'ed :yes:
  • 2 months later...
988629_10151523523274440_1554117959_n.jp
New intake plenum installed!! thanks to Vulture motorsport selling this one to me! was a perfect fit with my 850cc sard injectors :)
  • 3 weeks later...
hey mate do u sell the throttle adaptor plate seperately?? cheers
Hey!
Yes we do have them in stock - $100 delivered.
That comes with a back-plate and fittings.
- Brendan
  • 2 months later...
  • 2 months later...
Quick mention - these are also available in a 'raw' cast finish for those looking at painting them :yes:
Gday mate, what price do you have on the raw finish with larger throttle body and fuel rail. Posted to 2173?
Does the kit include everything needed to fit it to the motor and have it working correctly or will i need to buy any fittings or hoses etc?
Cheers
Cheers
PM Sent mate.
Cheers
Thanks for that mate, didnt get the Pm though? Would like to get one ordered soon!
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
    • So I'm in the final stages of assembling my single turbo RB30/26 and had a question regarding MAP reference points.  I've seen several recommendations such as tapping the cylinder 2/3 ITB, tapping the intake manifold at cylinder 2/3, or using a point on IAC. First two are doable but require permanently modify part and the third is "out" as I plan to delete the IAC.  All that to say my question is can I used the "bleeder" in the center of the ballance tube as a MAP Reference? I'm running a catch can so I don't need it for the PCV system. My thought process is it "pulls" from all 6 cylinder, and it's between the ITB and the cylinders making it ideal for MAP reference according to what I can find. Thoughts?
