Apparently upon bedding in a new mechanical diff you can either do figure 8's for 20 minutes
or
Have the diff specialist coat the disassembled plates with friction modifyer, then just drive off.
Still recommend changing oil after bed in.
What's the best way to go ?
Cheers
https://www.sau.com.au/forums/topic/303528-bedding-in-a-diff/
or
Cheers
Do what the diff manufacturer suggests.
As above.
Some diffs, like my Tomei (which I think is a re-brand of the KAZZ) suggest 20min of figure eights putting in the clutch before you turn in for the 180 degree turn at the top and bottom of the figure "8"
kaaz reccomend figure 8's for 20 min's in first gear (clutch in before turn, clutch out after turn)
nismo actually recommend going for a drive in the hills lol...
i did the figure 8's for 30 mins just to be sure, then dumped the oil...
i had a mechanical diff put into a previous car i had, i never did any of this i just didnt do burnouts and i changed the oil after like 1000kms, and that diff worked fine.... what a waste of fuel doing figure eights lol... a good mountain drive fair enough.
$2000 diff...
$5 fuel...
somehow i think its a worthwhile expense
Certainly is.
Anyway, I'll be having Award do the install for me.
For anyone whose been to them...
Where the hell in Seven Hills can you do the break in without getting arrested ?
lol i was reading this and thought people were taking the piss. As conan asked where are you meant to do this bedding in unless you time your diff install with a skidpan day
It has nothing to do with skidding the car.
Figure 8's can be done in as little as 200m2 so go to a shopping centre carpark on a Sunday evening. It doesn't require much thought.
yeah ok.
But my intentions are:
Have award change the diff,
Hopefully return to their workshop around 3pm ,
do the break in somewhere,
return to them immediately to change the oil,
then go home.
I'm a fair way from Seven Hills.
:P
oh my bad way i was reading it was your meant to be sliding the car whilst doing the figure 8's :) man im a retard haha
diffsonline.com recommend going no faster than 85 kph for 1200 miles !
That's going to be one boring drive.
Yep, I usually tell people no hard accelerating and nothing over 80km/h for the first 1000km to bed in the bearings, seals and tolerances. Then once in a while you get a VU SS ute come back after 200km missing half the teeth off the crown and stupid/honest enough to leave bald 20" tyres on the rear end :)
LOL, that's asking for trouble. "90 degree drift along the mountain pass is desirable."
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
