Hi all,
I've just picked up a 350GT for my daily drive (I love it!). I'm a little torn between simple power mods (I've read up on plenum spacers, Z-tube + intake and I'm pleasantly surprised at how cheap it is to make some more power and gain response from these engines) and suspension.
I was wondering if 350Z coilovers will fit a V35 350GT Coupe? I know the wheelbase is a little longer on the 350GT but I'm not sure on specifics. I'm sure I've read that they will fit, but perhaps on a US web site? I've search here but failed to find any related threads. Thanks in advance for any help.
Justin - coilover kits and swaybars are compatible. It's a popular mod on V35s to put Z33 suspension in them. It gives a 1" drop, with OEM ride quality.
From an "under the car" perspective, the main appreciable difference is the length. The area around the wheel well is pretty much identical, so all the suspension and braking bits are interchangable.
N.B. The front struts between LHD and RHD models are slightly different. I remember when I bought my Koni Yellows, I had to make sure I was ordering the front set of a RHD car. It's something to bear in mind if you source coilovers from the USA.
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
