I'm needing to change the inner driveshaft boot on the drivers side in my 32..
Just wondering what the process is in removal of parts etc, can you take the shaft out of the diff and slip it on that way, or does the hub / cv and all the rest need to come off then it slid down the shaft?
Wasn't able to find any info / service manual guide for this!!
https://www.sau.com.au/forums/topic/303548-r32-front-driveshaft-boot/
you'll need to undo the lower control arm and sway bar from the driver's side hub and the nut for the driveshaft to swing the hub out and get the driveshaft out. You should be able to pop the diff end of the driveshaft out with some levering and pulling without having to remove the diff cover. It's a tripod type CV so cut the old boot off and there's a retaining ring stopping the tripod from pulling out of the case which you need to remove. Thorough cleaning to get rid of the old grease and don't forget to slip the small end of the boot on the driveshaft before re-assembly. Be a good opportunity to do the outer one too, if it's looking close to replacement time.
