There is one between the compressor housings backplate and the compressor housing . I don't know what the price would be but it can't be that expensive .
Another thing is to make sure that the housings are to suit the same trim compressor wheel because HKS had 48/52/56 trim versions of the GT3037 . The "S" (inc Pro S) variants had the port shrouded compressor housing , the non Pro "S" ones could be had in 52 or 56 compressor trim sizes .
If you don't have part numbers for the housings simply measure the inducers bore diameter . The wheel inducer sizes are approx 55 and 57mm for the 52 and 56 trim wheels . The housings will be a tad larger at that point but should tell you which wheel they were machined to suit .
Cheers A .
