OSH13T Posted December 22, 2003 Share Posted December 22, 2003 If the turbo is not boosting till like 4500revs and not hitting max boost till like 5000revs and theres a wheezing sound coming through the air filter, would this be something wrong with the wastegate? If so will a external wastegate fix this problem? any help appreciated Cheers Link to comment https://www.sau.com.au/forums/topic/30357-wastegate-problem/ Share on other sites More sharing options...
Guest RedLineGTR Posted December 22, 2003 Share Posted December 22, 2003 What turbo are we talking about??? a stock r33 gtst turbo?? Link to comment https://www.sau.com.au/forums/topic/30357-wastegate-problem/#findComment-615697 Share on other sites More sharing options...
OSH13T Posted December 22, 2003 Author Share Posted December 22, 2003 yes, sorry mods: front mount turbo back zorst blow off air filter hks one Link to comment https://www.sau.com.au/forums/topic/30357-wastegate-problem/#findComment-615715 Share on other sites More sharing options...
qikr33 Posted December 23, 2003 Share Posted December 23, 2003 exhaust wheel sounds ***ed .Or waste gate staying open ,check the rod going from the actuator to the exhaust side of turbo u should be able to feel if it is closed .just replace the actuator or the vacuume hose to it. Link to comment https://www.sau.com.au/forums/topic/30357-wastegate-problem/#findComment-616966 Share on other sites More sharing options...
OSH13T Posted December 24, 2003 Author Share Posted December 24, 2003 exhaust wheel sounds ***ed .Or waste gate staying open ,check the rod going from the actuator to the exhaust side of turbo u should be able to feel if it is closed .just replace the actuator or the vacuume hose to it. thanks for the reply qikr33, wat do u exactly mean by checking the actuater if it is closed? From what I have seen, wen the car is boosting, the wastegate rod moves left to right, like a shudder. Is that what you mean? Cheers Link to comment https://www.sau.com.au/forums/topic/30357-wastegate-problem/#findComment-617612 Share on other sites More sharing options...
qikr33 Posted December 30, 2003 Share Posted December 30, 2003 yes but check that when its boosting that the wastegate does close off enough it may be too far open and not be regulating boost just leaking it out ...let me know how you go Link to comment https://www.sau.com.au/forums/topic/30357-wastegate-problem/#findComment-623127 Share on other sites More sharing options...
