lol laugh it Basti got done for everything cause petit just realized when no one rocked up it was a joke.
did he get your for GTA ? or did you prove to him it was your car ?
:P its "mums"
awww.... this was a funny thread... until one of us got owned :)
lol still funny cos im stupid
LOL I knew someone from this site would get defected tonight just out of coincidence.
I thought it was going to be me cause I was tailing a cop car going through the stop start traffic outside knox. Luckily he turned off into the police station :D
he said i can only have 1 air intake mod, but my cooler is black and the pod is in a box, its so unfair. and my blow off valve isn't even loud.
got me for height too, my car sits at 105mm, but my cat is at 98mm only a little bit under.
and also got me for being on my p's, but i had a fully sick sound system in the boot to weigh my car down so the ratio would be in my favor.
1 air intake mod is correct, if you have an aftermarket cooler you cannot have pod, even if its in a box :D
98mm is a bit ridiculous, I don't believe raising your car by 2mm will make it any safer...
Bad luck :)
Guys, I was there last night and no show. Only a Black R33 being defected.....was awesome, being there that is, not him being defected :D
We need re-organise this meet for Next Wed 20th @ 9pm back carpark at Knox City :)
aw shiet, I'm late to the gangbang as per usual.
Can we redo for next week? I'll even phone ahead and make a booking with the mobile EPA...
1 Step ahead.
For being so f**king awesome, Petett was clearly pissed that he'll never be as totally awesome.
since when was niggeroj awesome? I suppose he did just notch his car's awesomeness up a bit with better fitment.
1 Step ahead.
:huh: Get out of my head!
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
