Knox Tmu Meet
joeyjoejoejuniorshabadoo
 Share
Fvcking joke!
How is defecting cars keep the road toll down?
That is the biggest, lamest, excuse and they ain't doing themselves any favors.
>_<
Come on people WTF! Your first clue is "centre" mispelt as "center" in the first line of it. I thought us Skyline folk were smarter than this!!! :P
BAHAHAHAHHA what a tool! goes to show...even the people enforcing the law slip up... i dont believe he got fined n crap its just to make the public happy... i think due to human error.. at least 5 kays over the limit should be ignored.. not like 3 kays..
neway that's just my opinion.
How come it's 3 points for 10km over?
I thought it's only 2 points for 10-15km over the limit?
Used to be that way, it's not 3 points for over 10km/h.
The idea behind 3km/h is a threshold for incorrect speedos. According to the law you shouldn't be anywhere near the speed limit as it's just a limit and not the speed you're supposed to be doing, i.e. approximately 5km/h under according to TAC advertisements :blink:
From the Herald Sun article
"On this occasion I was very lucky - I didn't drift into a tree, I got snapped (by a speed camera).
Exceeding a posted speed limit ≠ drifting into a tree.
Normally I dont insult people on a personal level but this guy is a downright moron. I shudder to think how he could further ruin the state. I couldn't write a fictional article with that level of stupidity and idiocy within.
Edited by Bozz
"I need to be more aware. I'm luckier than a lot of Victorians who weren't. I'm still here to talk about it.
"Lots of people die in exactly those kinds of circumstances.
"It's been a valuable lesson for me."
that made me lol
Yer i read that and i was thinking the same. What happens if its 20 km over u fly off a cliff lolz to this bad
think he was saying that he was tired from driving in the country town, so he didn't notice the sign. and apparently that lets him preach about dozing off at the wheel which could result in people going into trees.
christ. nooblet got a speeding fine for going 10 over. way to turn it into something totally non relevant.
i better not type any more, cos my key stroke could distract the fly that carries the bacteria which could mutate into zombie flu, making it land into my co worker's coffee, thus starting a chain of reactions that will result in a zombie apocalype.
 Share
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
    • Here's the torque curves from the car I ramped boost up later in the rpm to allow a slightly wider useful power curve - the power curve is a bit weird shaped also thanks to the TVIS (or whatever they call it with the 4EFTE in this Starlet) which changes the volume of the intake manifold throughout the rpm range, but you can see that the green power curve actually holds later on with the extra boost... but looks almost more like the kind of thing you'd expect from a cam or exhaust change
