hehe i even got a pm from someone asking me how much was the fine for driving my car on my p's and for all the defects hehe told them it was just all a joke, and then jump the gun and fall for the false report with the date wrong haha.
I'll see you all when this dies down :banana:
hm. . . Forgot the old (insert sarcasim) . . . .
Haha, I just read the context of the thread I was replying in. Ooops, I probably shouldn't be reading 3 different things at once and replying :banana:
Knox 'hoon' gathering raided
January 13, 2010
The riot police were called to break up an organised meeting of hoons at Knox City shopping center. Hoons organise meetups on underground internet forums.
Last night, police received a tipoff the hoons were preparing to drive on a section of public road.
Police pulled over a single vehicle and issued a fine. At least 26 hoons evaded defects and fines by not appearing.
"We can't have hoons thinking they can take over our streets" Senior Constable Peter said. "When they organise to meet, they can be sure we'll catch and fine them".
He said the public must remain vigilant and report hoons by calling CrimeStoppers on 1800 333 000. "If you see ethnic people driving Nissan vehicles, report them immediately" he said.
Our road toll currently stands at seven. Police have promised to "unleash a fury" of defects and fines to keep the road toll down.
"Some people will never learn. We must keep our streets safe by removing hoons from Knox City."
:thumbsup:
Fvcking joke!
How is defecting cars keep the road toll down?
That is the biggest, lamest, excuse and they ain't doing themselves any favors.
:thumbsup:
    • I removed the IACV, cleaned it and reinstalled.  I found a video on youtube that helped with the whole process, the guy then said the idle needed to be set, so the process was to get the vehicle up to operating temperature, unplug the TPS, set the idle screw in the IACV so the RPMs were around 600, then plug the TPS back in.  After I reinstalled the IACV, the car started (because, it was a cold start), once it warmed up, the car died, I adjusted the idle screw to see if that helped anything, it did not, I had to wait about 3-5 minutes, then the car would start back up. Only to shortly cut out, and only crank.  I loosened the TPS to see if adjusting that would do anything, and when I would rotate the sensor clockwise, there was a humming noise, but it would go away when I got the sensor in the horizontal position.  It only made the hum noise with the key on.  What do you guys think? 20250414_172604.mp4
    • Quick update.  The engine grounding strap was replaced, the engine is now happily running.  Tested the voltage drop before replacing the strap, was about 1.2ish volts down between engine to battery, chassis to battery. With the new grounding strap, pretty much no voltage drop at all.
    • I was chatting with an ex SAU person who is involved in chooning euros now. He was saying the factory cars like Audi VW etc have something like 2000 tables that the ECU uses for getting everything "just right". Compare that back to any aftermarket ECU, and you'd be hard pressed to surpass 50 lookup tables. Even the Ford Barra engine has a few hundred lookup tables to run it (and they're still working some tables out too!)
    • Grab a temp probe, and probe each exhaust inlet runner with it sitting idling. Each one should be pretty darn close to the same temp. If you've got some reading higher or lower than the others, it's likely either air flow isn't equal, or your injectors aren't equal to each other.   The other things to check, is from the wiring changes that were made, were any earth's or grounds moved/changed.   Lastly, for the strut brace issue. It's not perfect, but can you get away with slipping a washer or two under the strut brace to raise it, and it still clean the bonnet? If you can, work out the height you need, that the motor can't torque up into, and get a spacer made for each side.
