260rwkw Is My Goal
da spike
 Share
Hi,
As the topic states I'm trying to achieve around 260rwkw and just need some advice on a couple of things.
Car: R33 S2
Current:
Std Turbo
Std Injectors
Std AFM
Just Jap FMIC
Apexi AVC-R
Walbro 500hp internal fuel pump
JJR Coils
Toshi re-map
Exedy Heady Duty Clutch (put in 3000kms ago)
3" dump and 3.5" catback with hi-flow cat
Proposed:
S15 480CC injectors
Hypergear R34 OP6 hiflow turbo
Z32 AFM
Toshi re-map
I read in a couple of posts that people had some issues with the Walbro fuel pump but this was mainly with a 450HP one. This one is 500HP and I'm just wondering whether anyone has any experience with this one? What about the FMIC and clutch?
Any feedback would be appreciated.
Thanks
Edited by da spike
Toshi does wonders, my car was running like shit before his tune with heaps of flat spots but now its very smooth and revs out much quicker :huh:
Edited by da spike
  • 3 weeks later...
Ok I have some questions:
I have sourced the s15 injectors, z32 AFM and just waiting for the turbo to come in from Hypergear.
Can I put in the s15 injectors for the time being and drive the car normally? I read in some posts that it should be ok but I just wanted to double check this.
Also once I wire up the z32 AFM will I be able to drive the car to get it tuned or will it run like a dog?
Thanks guys.
You will need to scale the injectors through the ECU to get them running properly. You can't just install them and then drive the car.
Edited by PM-R33
as above just drive it there stock and fit them once you get to the tuners.
on the subject of turbo, why not go the Hypergear Powered Up "PU" hi flow. You are already purchasing an R34 OP6 housing anyway so you may as well get a 0.82 housing.
They have a dyno of one making 269rwkw and 272rwkw on an R33. The R34 OP6 housing looks to make more around 250rwkw.
Edited by Harey
He will make 260rwkws+ on the OP6 with the actuator supplied. The PU high flows are capable of doing lot more then 270rwkws.
Sounds good but what is the cost difference between an OP6 and a 0.82 housing? Seeing as though the OP6 housing has to be purchased anyway as he has an R33.
The only reason I would stay with the standard type hi-flow is to stay legal ie look completely standard from the outside. Once thats changed by using an OP6 housing, I reckon go all the way with the 0.82!
I already had a blown r34 turbo with OP6 rear so I just sent that in to get highflowed :)
I was thinking about getting the powered up highflow but I'll be happy with 260rwkw and no need really, i'd rather a tad more response.
Thanks for the replies guys looks like its getting trailered there.
can drive with 480cc injectors and the standard ecu, it'll run richer and will foul plugs quicker but other than that it wont do any damage. wire the z32 plug into the standard afm wires without cutting them so you have both plugs in there, makes swapping the afm a 5min job if that. car will probably run with the z32 and 480s if you have to limp it to the tuner, just keep it off boost.
I already had a blown r34 turbo with OP6 rear so I just sent that in to get highflowed :cool:
Thats sweet then!
I will prob do the same one day as I would love to keep the exterior of my turbo 100% standard. Keen to see what power you can get out of it!
I am fairly new to skylines but with commodores you could change the injectors within about 5 mins. I once just changed them in the tuners car park. What sort of job is it on an RB25?
I like the afm idea.
It doesnt seem too hard, theres a DIY article about it on here, I dont think its a 5 minute job though lol.
http://www.skylinesaustralia.com/forums/In...mp;hl=injectors
Edited by da spike
 Share
    • In no way was i suggesting it’s your fault mate. The trailer cable has a plug that I removed. I will have a closer look, but I did remove the trailer wiring cable with the tow ball as I don’t need it on my silo. i have replaced the fuel pump already there’s no need to remove the cradle again I can see the wire colours from it in.
    • Mint. Good to see another GTSt getting love and coming back to life. Did I miss what colour you are going to wrap it?
    • So far, based on the maps. Looks like 42 frame size 68mm & 72mm And 45 frame size with 67mm and 73mm
    • Another complicated thing is to run Z32 alloy hubs which have wheel speed sensors for ABS. You need different tie rod end, and you need new bearings on the upright etc. I did that as part of a major refresh when my front kingpin bearing flogged out., Alloy was a little lighter, runs a bigger bearing , gives a few extra mm in wheelbase as it moves the wheel forward in the arch (cant run crazy but can still get 8ish comfortably).   All in all glad I did it but was a head fark as tried it once and abandoned it the first time. sav man swung his spanners at it and got it working so using his guidance on GTR/Z32 tie rod ends etc and the required mismatch of parts was able to make it work.  Probably a 2k upgrade all said and done :(   I think the best bet is just look around your front wheel and see what you can pick up rotationally. You see old Escorts, E30s etc all get very creative with front uprights and the humble old angled alloy bracket.
