Cruise To Motorvation
Hanaldo
 Share
Hey everyone!
Im sure you all know Motorvation is on this Weekend, 16th and 17th of January biggrin.gif
I thought it would be a good idea to see who wants to cruise down to the Kwinana Motorplex together on Saturday? Just a good way to kick things off. Gates open at 10am, so we could discuss a good meet point and meet time and then cruise down there?
And just on a side note Martin - i wonder what my car and your car would be like in a straight line.
I mean they are both 2.5L straight 6 motors, both cars would weigh roughly the same, but then the cars have different ratios etc. I reckon they would be pretty much on par straight line speed wise, maybe yours would be a little quicker....
P.S. I'm not asking for a race, just wondering, that's all :banana:
Ok cool man, im around the hills area, so maybe we could meet Midland? Then cruise down Roe hwy, etc?
I also think both our cars would be evenly matched hey, although does yours have traction control? If it does, i may have an advantage with that if you can't turn it off :P
Anyway, anyone else interested in meeting at Midland at say 8:30am for a 9am leave?
if i dont go to westrac that morning i might , do we get in cheaper if we part of sau ??
Not that i know of dude, why is the orientation day on a Saturday? Thats stupid
Its Westrac Man of course its going to be at the most inconvinient time Lol Its Only Like Till 11 then i Guess me And Tyson Can Drive Down After :P
If i go down on saturday morning, ill want to be there by ~930am or so. Cause ill have a lot of running around to do on Saturday morning (washing the car, getting drinks, food, getting tyres + jack for a mate).
I'll let you know by Friday day sometime mate.
Yep, i can turn traction off :huh: lol, no LSD though ;)
Ok ive just found that i won't be able to make it down before lunch time, something came up. Sorry about that Jason :banana:
So does anyone want to do a meet in Midland or somewhere near there at say 12:45pm for a 1:15pm cruise?
Yeh i saw you guys leaving, gave you the thumbs up but you didnt back :) lol. f**king sick day, so many skids :P:D Steve Jones once again does an awesome skid in his GTR lol
lol I did give you a thumbs up but I only saw you just before you passed.
Which GTR was that?
saw quite a few 32's and 33's out there and the purple 34
Which GTR was that?
Yeh the purple 34
I got back about an hour ago, was good. Too many V8's and bogans down there, but hey, it is Kwinana. Also spotted [MONGA] down there on the super cruise in his 32R :P
 Share
    • After I unplug maf car dies, won’t start. Same with iacv valve - two connectors mounted behind manifold
    • here’s link to photos bcs can’t add it here blue spots - I can install recirc valve hose there and in general everything air intake related so you can spot of anything wrong here
    • Sorry for late answer but here’s my spec: Series 1 1994 r33 gts25t AT converted to MT using r32 rb20det gearbox. Custom self made clutch pedal os giken twin plate clutch two pins connected to let engine start speedsensor from AT connected to wire harness but didn’t fit to gearbox So it’s somewhere inside in the car so I can add km to tachometer after I measure distance with gps. Don’t want to pay 150€ for sensor if I probably will change gearbox with adapter to bmw one. Car barely runs and winter is coming so no point right now  engine after rebuild Stock automatic ecu and at tachometer Aftermarket oil cooler with separate sensor so oem oil pressure is unplugged  koyo 53mil radiator  Mods which may cause the issue: 600x300x76 front mount intercooler Cone air filter blitz Removed recirculating valve Slighty bigger maxspeedingrods turbo adjustable manual boost controller (didn’t set it but last time I checked on aftermarket gauge it was 0.4bar, asaik oem is different unit 7(unit) don’t want to rev it too high bcs it made max 70km after rebuild Fuel pressure regulator set to idk 30-32psi at iddle dw300 fuel pump stock injectors check valve right in front of fuel rail i thinking sth wrong with afr it getting too much fuel and too less air or it needs that recirc valve? on warm engine it took 5-10 seconds to start it. After I put way bigger battery, battery terminals and new ecu coolant temp sensor problem is gone my old turbo spill 150ml oil into intake so cleaned it.    I checked for error codes and it given me 55 - all good. I bought consult so will plug in soon to check if it give me better feedback. Also I will install oem recirc valve tomorrow. Small hose going to manifold but where should go 30mm pipe from this valve? I’m front of turbo inlet, after maf/ right after turbo outlet / or it doesn’t matter? actaully can install it in these two spots (blue circles)
    • I think throwing the hydraulic power steering system into the trash and converting to electric power steering, e.g. Astra PS pump would solve many issues.
