Evening All,
Well myself and chefstagea's wondering start out when the dude selling this Stagea For Sale On EBAY posted up in his ad something along the lines of "plugs changed including the plug near the oil filter that most owners dont know about". Has anyone herd about this? I never have and dont really believe it... I cant find where he says it in the advert know as I think he's edited it but I did send him an ebay question about it and got this reply:
"Dear kidafa,
my mechanic said he found it behind the oil filter mount when he did the last oil change - told me it wouldn't have been found without the mount coming off.
- peterh9905"
Can anyone shed any light?
Cheers,
Chris
https://www.sau.com.au/forums/topic/303612-plug-behind-oil-filter/
sounds like BS to me, on quick read of the description and you can tell he's a peanut (not to mention never heard of the "plug") i mean look at the Nissan badge he had made that says "INSANE" what an absolute WINNER! wouldn't believe a word he said.
i saw that ad last nite too,unsure what he's talking about tho chris
and before anyone goes a calls him a "peanut" he used to own a well known import workshop in adelaide and is super into his stags and is quite well informed about them
f**k knows what hes talking about tho
AFTERMARKET HPI BUNCH OF BANANAS TYPE LOW MOUNT MANIFOLD - CAR DOESN'T USE AS MUCH JUICE ON THE HIGHWAY WITH THIS MANIFOLD AS THE ENGINE DOESN'T NEED TO SPOOL THE TURBO AS HARD
hes a winner alright
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
