Hi everyone i just had this idea to put my rx7 on a skyline forum haha im an idiot but anyway this is my RX7 S4 with a RB30DET engine it.
building for drift hopefully to be professional one day
Here are the specs:
Rb25 head, o-ringed, ported, bigger stainless valves, heavy duty valve springs, camtech cams(will put specs on picture)
adjustable cam gears (no VCT)
RB30 bottom end
o-ringed
forged CP pistons (8.5 comp)
spool rods
race bearings
copper head gasket
custom sump
oil filter relocation/cooler kit
custom engine and gearbox mounts
greddy (copy) inlet manifold
80mm thottle body
high mount turbo manifold
50mm external wastegate
To4z turbo (coming soon)
3 inch dump pipe then split into two 2-3/4 inch with two 4-1/2 inch canons
1000cc injecters
big fuel rail
1000hp fuel pressure reg
twin bosch 044 fuel pumps
1/2 inch fuel line
57 litre fuel cell
battery in boot
microtech LT12S
6 bosch coils seperate from engine
R33 gtst 5 speed
rx7 s4 turbo locker diff
coilovers
and other things i just cant think of at the moment
this is a 3 year long project so far and hoping to finish in a couple more months, it started as a s2 rx7 and i changed shells 6 months ago.
im currently in progress of painting it candy apple red, ill add some more pics after its finished painted. anyway here are some pics let me know what you guys think cheers.
https://www.sau.com.au/forums/topic/303638-rb30det-rx7/
  • Replies 43
thats a fantastic effort... but the only thing that comes to mind is WHY??? :rolleyes: why would you take a light weight and perfectly balanced car like the rx7, take out the lightweight 13b capable of ridiculous power, and drop in a big heavy cast iron rb30??
https://www.sau.com.au/forums/topic/303638-rb30det-rx7/#findComment-5032249
RELIABILITY
https://www.sau.com.au/forums/topic/303638-rb30det-rx7/#findComment-5032301
i can dig that.. should hammer nicely.
coz rb's dont have any oil control problems causing catastrophic bottom end damage. :thumbsup:
While yes they do its easy enough to fix/reduce it.
Rotarys on the other hand running on 2 stroke helps but still you would have to rebuild it a heap making good power
https://www.sau.com.au/forums/topic/303638-rb30det-rx7/#findComment-5033757
you should have a read of the "why do rotories suck" thread.. they arent as bad as the rep they have for being unpredictable and unreliable.. its all about calculations and driver care.. no different to any car or engine.. plus an rb26 rebuild can cost anywhere from $10000 to $100000.
its easy enough to fix/reduce a rotoray. rotors can be pulled apart, have the apex seals replaced, and put it back together like a sandwich. they have advanced greatly with the seal technology and dont have nearly as many dramas. you may have to replace the seals 5 times to the RB's 1, but its not that hard or expensive and the rewards of the rotary engine make it worth it.
making good power, and making usable power are 2 different things, you can have a ball breaking rotor that is on the limit and gets constantly flogged on dynos/strips.. or you can have a more sedate, well rounded street package that can have no dramas at all and is still ball breaking, but nowhere the limit of explosion.
it all comes down to engine building, tuning, and purpose.
https://www.sau.com.au/forums/topic/303638-rb30det-rx7/#findComment-5033901
what sort of power will i be making with a garrett to4z ball bearing turbo? because i want to make 600+HP atw, i cant go too big on the turbo because the car is for drift and dont want too much lag. GCG turbos said it wont get the power im after with a to4z but said i will with a t51r but that is too big and have too much lag wont it?
Edited by SICRX7
https://www.sau.com.au/forums/topic/303638-rb30det-rx7/#findComment-5034683
so the car is for drift but the engine is a dyno queen??
for drift, a gtrs, 2530, td06, td07, etc, will all be fine. the rb30 should be able to spool up a bigger turbo nearly 1000rpm earlier, so a t51r might not be such a silly idea.. if garrett said your t04 wont make the power, than i guess they are the ones that would know.. but they make 400hp on a rotor, so maybe they dont know.
you cant have both worlds, you either want a ball breaking dyno queen, or a drift car that you can actually get out and thrash.
https://www.sau.com.au/forums/topic/303638-rb30det-rx7/#findComment-5040217
yeah i understand i might just go with a to4z because a t51r would be overkill and have too much lag
https://www.sau.com.au/forums/topic/303638-rb30det-rx7/#findComment-5050311
Madness. Love it.
But seriously, area under the curve is much more important then having X amount of power for drift.
What inlet manifold do you run bloke?
Edited by Flipmo
https://www.sau.com.au/forums/topic/303638-rb30det-rx7/#findComment-5062147
I farken hate you mate! Ive dreamt of doing that exact same project for so long. Ive always been torn because i love skylines as well.
Good luck with it though. Its looking awesome and im insanely jealous!
Question though? Have you beefed up those engine mounts anymore since the first pic of them. Where the two halfs join at the bend. It doesnt look to be very reinforced (gusseted) for the sort of weight that will be hanging off them. I know those drift cars can bounce around a fair bit on tracks and also when they run off the track and the hard suspension wont help it much either (though i am assuming you will be running hard springs as thats what most do when running *JAP* spec drifting coilovers.
https://www.sau.com.au/forums/topic/303638-rb30det-rx7/#findComment-5072229
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
