would have been pretty nice of them to put them back on after they took the teins out!
lol im just saying,,she didnt mention the rims were gone :rolleyes:
  • Replies 59
Posted Images
you live in the dirty south and are only just realising it :banana::P
Did live in the south up until last year, currently a westerner.
Still more of the bad stories seem to come from up north than south. A friend of mine lived in an un-named northern suburb. Had the cop cars & choppers around his way all the time. Don't see it down south that often....
Didn't say it was a squeeky clean area. But there's pleanty worse, lived there most of my life & relative to other parts it's not that bad IMO.
Having said all that how about we all move to the country (don't tell any gangs) hit the whole joint with a network of C4 and start anew. Would do wonders for our supposed housing crisis!
Edited by J_Red33
yeah we have a running badgering between south and north with who is worse
i sort of live on the northern boarder still in a good area but the scum come up here to steal the good cars and brake into good homes
no there wasnt any insurance on the car, was only new a few weeks ago.
rule of thumb.....get insurance before you even get in the car
2 weeks or 2 days you could have had an accident into someone's ferrari for example and then be paying for life....not good :thumbsup:
um, how long does it take to rip 4x coilovers off a car?! These guys managed to do a job that i'm guessing would take most mechanics a couple hours in total (including the interior) and no one noticed. They also had to have done it at the skate park because they obviously couldn't drive it there afterwards...
No insurance at all? not even 3rd parth? seriously thats risky - what if you hit a ferrari or a porsche or something...or any car at all really...
yeah so far no one has noticed or said anything. this was done within a hour.
no insurance at all =/
Edited by skylinrGirl
No alarm or clublock either im guessing? Or considering they knew how to remove the coilovers in less then a few hours, they probly knew how to disarm an alarm system.
Guessing they spent all their money at marion and needed a ride home..
no alarm..
nuh dont think they needed a ride home.
in ways they knew what they were doing but in other ways they didnt.
no alarm..
Why not? Not only a ride home, some parts to flogg off for some extra cash on ebay...
Sorry to hear anyhow, i know first hand how it feels to have your pride and joy stolen..
    • Good news!!! Changed the O ring today and Iโ€™ve got the โ€œpssshhhhโ€ back when I open the fuel cap ๐Ÿ˜‚๐Ÿ™Œ๐Ÿผ๐Ÿ™Œ๐Ÿผ It was 100% the O ring because that bloody thing was inside the fuel tank ๐Ÿ˜‚๐Ÿ˜‚๐Ÿ˜‚๐Ÿ˜‚๐Ÿ˜‚ Fitting new fuel pump was a pain as always since the DW is a bit longer than stock. But sheโ€™s running!!! โค๏ธ
    • PWM quite literally just chops the ful 12V voltage on and off at whatever duty cycle you're running it at. If you're running it 100%, then it is on full voltage all the time, same as if there was no PWM. If you run it at 50% duty cycle, it is only seeing the full 12V half of the time. This is broadly equivalent to running it at 6V. But the crucial difference is that motors (and a lot of other loads) don't like being powered at low volts. They will either fail to start rotating, or draw a shit ton of current, or other undesirable things. But if you give them the full volt, and then a short period of no volts, and then some more full volts, then the times when they are seeing power they are seeing all the voltage, and they are happy. But you get the performance out of them as if they were only seeing that fraction of the full voltage. It is not really easy to answer your question about what flow you will get out of it at 50% duty cycle. I can tell you that it is not as simple as you think. For a start, that 460 L/h pump is not going to flow 460 when you're on boost. When you're on boost you will be somewhere down the sloping part of that red line. If you have 15 psi of boost, then the pump can only deliver about 95 gal/h, which is <380L/h. So your simple 50% on 460 = 230 wasn't going to work anyway. But also, it won't deliver 50% of 380 either, because when you devolt or PWM trim th epower being fed to the pump, it is not able to deliver flow or pressure in the same way. 50% duty cycle will probably produce <50% of the full voltage flow. The way to find out what duty cycle you need to run it at at low load (ie, at idle) is to idle it and turn the DC down until you start to lose fuel pressure, then turn it back up above that with some extra for safety. And then you do the same thing at full load, in case it doesn't need anywhere near 100% DC. And if you're careful/caution/prudent, you will also do it at a couple of loads in between so you can shape the DC map against load. It might not be linear between the two end points.
    • Man that dinner was such a long time ago....2010! I would only replace the rubber coolant lines with silicone these days; cheap, readily available and will last for ever. You will need new hose clamps though egย https://justjap.com/products/cooling-pro-silicone-engine-heater-hose-set-black-nissan-r32-gtr-rb26dett
    • I wouldn't look too hard at what they did with the R32 GTR in endurance racing in Australia... Lots of things weren't actually available from the factory in the way those cars ran them... Japan also followed what Fred Gibson was doing here with some of there endurance cars in Japan... Australia is also the reason for things like the Brembo brakes, and the change in the gearbox... And quite a few other tricks they used to pull. There's a few other SAU peeps still on these forums that will have heard the stories direct from Alan Heaphy, Fred Gibson, and Jim Richards when we were lucky enough to have a great dinner with them
    • For all the talk of "these parts are junk" I generally recommend OEM because it's really not as bad as claimed. I have never seen or heard of a case like the N63 where the oil returns completely clog with coked oil for example in ~10 years or less. Would it be nice if it were a straighter path? I guess, but most modern cars use a scavenge pump instead of a pure gravity return. Also the factory lines that would be relatively simple to convert to braided are generally speaking hardlines from the factory. I would consider braided line to be a regression, not an improvement. It's also been engineered such that all the hardlines have appropriate strain relief where needed. There's absolutely room for improvement, for example the HKS advantage heritage intake piping shows just how much can be done to make the turbos fight each other less in OEM twin turbo configuration and reduce compressor surge but it's rarely a simple/straightforward process. I recommend looking at what the group A/N1 cars did, generally speaking the changes they made were necessary and proven in endurance racing.
ร—
ร—
