hey everyone i am new to skylines australia and i am new to skylines.
i just bought a r33 GTS-4
RB25DE
KYB Struts + King Springs
2.5" Exhaust with Highflow Cat
Greddy Strut Brace
Rebuilt Gearbox
Front + Rear LSD
ect ect ect...
Just wondering what the standed specs are on these, Are they rare?
Do they go good? and add on to make it more powerful
Edited by niiko101
https://www.sau.com.au/forums/topic/303667-r33-gts-4/
  • Replies 50
Their a great starting point.
My 32 used to have the 4wd system and an NA 25.
Do they go good? Well it depends on what you want to do with it. The key to driving a 25DE quick, is never let the revs drop below 4500-5000 RPM and point to point, its not a bad little engine.
The 4WD system is great for when things get hairy. If you find yourself in a pickle, the hardest part is to resist the urge to lift off, but keep it flat, let the ATTESSA kick in, do its thing and straighten you out.
25DE's have around 100RWKW stock.
https://www.sau.com.au/forums/topic/303667-r33-gts-4/#findComment-5031578
Got a 33 gts-4 myself awsome car with lsd, works well for p plates...and basically as for engine upgrades alot easier to drop in a rb26 if u wanna twin turbo it later which is what ill be doing once off my p plates...
What are u looking at doing with it mate?
https://www.sau.com.au/forums/topic/303667-r33-gts-4/#findComment-5032218
well the body is in pretty ruff shape. small rust over the wheel arch, tiny cant notice it and just 3 4 dings all over it and starches and stone chips all round so was going to fix that up and put some tanky offset wheels on it and a body kit. just really want to know the N/A mod for a rb25de for some increased power
https://www.sau.com.au/forums/topic/303667-r33-gts-4/#findComment-5032224
yayyy GTS-4's!!!!!
They are pretty rare. The po po dont even know what it is.
The truith is they are hard too mod because you have too stick too the rule of thum, more fuel and air will increase power and being a NA there are not many ways too do that let alone much ways too get the power. You have too cut straight too spending more money for slight gains.
My GTS-4 has oversized pistons too 50thou for now. It was my first mod and i wanted to make sure the block was out of the way, i also recondictioned the whole block and top end but with that out the way im only 10% of the way there and gained 20kw so far for the upgrade and rebuild (sitting on 121KW at the wheels)
https://www.sau.com.au/forums/topic/303667-r33-gts-4/#findComment-5032522
hahah thats what i did! goes a lot better and really shows the potential of the 4WD.
It is pretty rare, when I say gts4 ppl think its a 4door.
Will be a bit of a pickle trying to source some phat rims with a 4 stud though. But there out there. OR do a 5stud conversion (got som bits n pieces left over from mine) hint hint*.
When mine was NA i had 2.5' extractors and cat back + pod etc bolt on stuff and mid 14s -15 at wsid was bout as much i could get it to go with bolt ons to give you an idea.
https://www.sau.com.au/forums/topic/303667-r33-gts-4/#findComment-5032752
are they 4 stud? i thought r33's where 5 stud
https://www.sau.com.au/forums/topic/303667-r33-gts-4/#findComment-5033143
what you ahve left over from teh conversion? ive been wanting to do it for a while now and change to 5 stud with bigger brakes, but just before i was about to buy the gtst hubs ect i heard that the gts-4's needed the hubs of GT-R's??
https://www.sau.com.au/forums/topic/303667-r33-gts-4/#findComment-5033199
Front hubs yes. To allow for front drive shafts
https://www.sau.com.au/forums/topic/303667-r33-gts-4/#findComment-5034495
thats true. Only hubs that will fit properly are ones from GTRs and Stageas. (got a pair of r33 gtr hubs goin cheap if any1s interested :thumbsup: )
https://www.sau.com.au/forums/topic/303667-r33-gts-4/#findComment-5034856
strip it down and put it back together gave it a full clean inside, re did the system, rewired the front bar theres just one more problem ill try to get a video of it to show you all maybe you can help me out
https://www.sau.com.au/forums/topic/303667-r33-gts-4/#findComment-5042488
a good upgrade might be a factory GTR clutch and flywheel (from early R32) i have a billet lightweight GTR flywheel and Excedy HD GTR clutch in mine, clutch grip is phenomenal (second gear clutch drop lights all 4s with fat tyres) on RB25DE+T but you pay for it with your left leg, it is brutal heavy and bitey, Ive got a mate with a 4000lB Jim berry full monty clutch, and that's light as a feather compared.
https://www.sau.com.au/forums/topic/303667-r33-gts-4/#findComment-5048819
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
    • Are you doing the work yourself or are you paying for labour?
